Arrange the vertical aligned beam within a rectangle with horizontal alignment
I have to compose the sheet for printing in our office. We have all the beam arranged vertically in the drawing. We want a lisp so that it arranges the beam within a rectangle. The rectangle can be of any size.
NOTE:
The beams are already enclosed in a rectangle on a specific layer named Raft Beam.
The beams are to be arranged in any order so that maximum space within the rectangle is used.
I have enclosed an example of the drawing.
Thank you in advance.
dbhunia
Try this............ (Extended part of your previous post............ This)............. I have considered your Vertical order Top- bottom  into Horizontal order Left-Right.
You may need to do some work in the drawing ............
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
dani-perez
Hello dbhunia,
Thanks for the lsp, it's very interesting. Could be from Vertical order bottom-top  into Horizontal order Left-Right?
dbhunia
Yes it is possible ....... Now I left office ...... give you solution later.....
Debashis Bhunia
dbhunia
Change this line.......
(setq Rec_Cor_Sor (vl-sort lst_Sor (function (lambda (e1 e2) (> (cadr e1) (cadr e2))))))
into.......
(setq Rec_Cor_Sor (vl-sort lst_Sor (function (lambda (e1 e2) (< (cadr e1) (cadr e2))))))
Debashis Bhunia
dani-perez
Hello dbhunia,
It works perfectly!!
thanks.
