- Mute
- Permalink
- Report
Hi, I have this DWG attached .I need to make this drawing a block that some objects can be rotated (from A to B). This is just an example the actual drawing is more complex.
Is there a way to create a lisp routine so at first I will choose the elements i need to be with a rotate parameter and then the entire drawing and the result B will come up?
Thanks you very much for your help
