Hi, I have this DWG attached .I need to make this drawing a block that some objects can be rotated (from A to B). This is just an example the actual drawing is more complex.
Is there a way to create a lisp routine so at first I will choose the elements i need to be with a rotate parameter and then the entire drawing and the result B will come up?
Thanks you very much for your help
Solved by Moshe-A. Go to Solution.
1st step is get a copy of Lee-mac Dynamic block properties, you can use the code to set the value of Angle1.
(defun LM:setdynpropvalue ( blk prp val )
(LM:setdynpropvalue blk "Angle1" ang)
Thanks sir, this is what I found but still cant understand how to modify it to achieve the whole block so that the entire drawing will be included in the block but just some of them will rotate.
;; Set Dynamic Block Property Value - Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(setq prp (strcase prp))
(vl-some
'(lambda ( x )
(if (= prp (strcase (vla-get-propertyname x)))
(progn
(vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
(cond (val) (t))
(vlax-invoke blk 'getdynamicblockproperties)
@yu85.info wrote:
...to achieve the whole block so that the entire drawing will be included in the block but just some of them will rotate.
I'm having a hard time understanding this @yu85.info.
entire drawing will be included in the block? Does that mean after the selected dynamic blocks are rotated, convert all the objects on model space to a block?
Thanks, I will explain. The entire drawing should eventually be a dynamic block which some objects in it will be able to rotate and some not.
I am not quite sure I understand what is a nested block but in this DWG attached there is the final result.
Thanks agian
@yu85.info hi,
check this 😀
Moshe
(defun c:mlro (/ adoc ss0 ss1 ang bname ename)
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startUndoMark adoc)
(princ "\nPick a block...")
(if (and
(setq ss0 (ssget ":s:e+." '((0 . "insert"))))
(setq ang (getangle "\nRotation angle: "))
(progn
(setq bname (vla-get-name (vlax-ename->vla-object (ssname ss0 0))))
(if (setq ss1 (ssget "_x" (list '(0 . "insert") (cons '2 (strcat bname ",`*U*")) '(410 . "Model"))))
(foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss1)))
(if (= (getpropertyvalue ename "isDynamicBlock") 1)
(setpropertyvalue ename "AcDbDynBlockPropertyAngle1" ang)
); if
); foreach
); if
); progn
); if
(vla-endUndoMark adoc)
(vlax-release-object adoc)
(princ)
Are you selecting dynamic block?
i just update my code so copy & paste it again
also if the dynamic property name is not "angle1", it won't work
I appreciate your help. I think I have not explained myself well.
I attached a new DWG's. All the objects in the drawing should be in one block. The objects in yellow should be with the ability to rotate. The lisp I am looking should ask me to pick objects (I will choose all the yellow ones) to pick a point (I will pick a point) and set this point to a be rotate parameter of an angle of 360 for all the yellow ones in the block.
I attached a DWG of "Before" and a DWG of "After".
Of course that has been done manually. I am searching for an automatic way.
Thanks again for your time sir
before.dwg the drawing is not a block
after.dwg the drawing is a dynamic block with rotation on some of the objects in the block
can you see the difference now sir?
for some reason someone marked it as solved but it has not have been solved
@yu85.info wrote:
sir, you marked my question as a solution but it has not been solved
Are you sure it was me? I would not knowingly marked somebody else's solution especially if i have nothing to do with it? Its not even on my list of recent activity.
That is very strange. Anyhoo, i can remove the "accepted solution" if you insist.
first this thread is still not closed
second check this one 😀
At select objects pick the objects you want to be in your dynamic block (you do not care about block name at all?)
it selects only those yellow objects. also you need to specify the Rotation base point: for the dynamic property rotation (angle1)
work?
Moshe
(defun c:WrapDynBlk (/ genBlockName ss p0 bname)
(defun genBlockName (/ name return)
(setq name "$temp")
(setq i 0)
(while (tblsearch "block" (setq return (strcat name (itoa i))))
(setq i (1+ i))
return
); genBlockName
(setvar "cmdecho" 0)
(command "._undo" "_begin")
(if (and
(setq ss (ssget '((62 . 2))))
(setq p0 (getpoint "\nRotation base point: "))
(progn
(setq bname (genBlockName))
(command "._block" bname "0,0,0" "_si" ss)
(command "._bedit" bname)
(command "._bparameter" "_rotation" p0 0.5 "" "" "")
(command "._bactiontool" "_rotate" (polar p0 (/ pi 4) 0.5) "_si" "_all")
(command "._bclose" "_save")
(command "._insert" bname "0,0,0" 1 1 0)
); progn
); if
(command "._undo" "_end")
(setvar "cmdecho" 1)
(princ "\nDone.")
(princ)
); c:WrapDynBlk
Hi, first of all it works prefect! but sorry for my rudeness... is it possible to add a second selection which will include the other objects in the drawing in the block (the yellow ones, I select, will be the only one who can be rotate)
And if it is not to hard to add an option to give a name to the block
Thank you so much for your time
