Lisp for calculating geometric properties
rafael.bizarro
Message 1 of 28
rafael.bizarro
Good afternoon my friends. I really need a help to elaborate this LISP according to the step-by-step in the image below. I would be very grateful for your help. Thank you in advance.
Replies (27)
Message 2 of 28
rafael.bizarro
If it's too complicated with hollow figures. It might just be with massive figures. (like the 1st example)
Message 3 of 28
Sea-Haven
A quicky, use bpoly then (setq pt (osnap (vlax-curve-getStartPoint (vlax-ename->vla-object (entlast))) "gcen")) this is geometric centre not sure if centre of gravity will have to check. Then erase last, and make a new one add answer to table. So long as shape is one bpoly. A double "I" touching will give wrong answer, must have the sections removed that touches like image.
Post a dwg with a couple of shapes and a table.
Message 4 of 28
hak_vz
@rafael.bizarro  When posting request to this forum always attach sample drawing. This helps us to create your code without too much fuss. What we have in jpeg my not represent fully how your drawing  is created i.e using lines polylines, different measuring units... you name it.
Miljenko Hatlak
Message 5 of 28
rafael.bizarro
Ok! Ty for the tip! Here it is the dwg.
Message 6 of 28
Kent1Cooper
Try this as a start:
(defun C:WHATEVER (/ *error* perim file minpt maxpt LL UR pickpt cut inc ent outer inner outerobj)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    ); if
    (close file)
    (princ)
  ); defun - *error*
  (setq
    perim (car (entsel "\nSelect outline [outer perimeter if hollow]: "))
    file (open "C:/Your/File/Path/YourFileName.csv" "w"); <-------EDIT filepath and name
  ); setq
  (write-line "Step,Area,COG depth,Product" file); headers  <-------EDIT wordings
  (vla-getboundingbox (vlax-ename->vla-object perim) 'minpt 'maxpt)
  (setq
    LL (vlax-safearray->list minpt)
    UR (vlax-safearray->list maxpt)
    pickpt (list (/ (+ (car LL) (car UR)) 2) (- (cadr UR) 0.5)); 1/2 unit below top middle
  ); setq
  (command
    "_.zoom" "_object" perim ""
    "_.xline" "_hor" "_non" UR ""
  ); command
  (setq
    cut (entlast); the Xline
    inc 0
  ); setq
  (while (> (caddr (assoc 10 (entget cut))) (cadr LL)); still intersects
    (command
      "_.move" cut "" "0,-1" ""
      "_.boundary" "_advanced" "_object" "_region" "" pickpt ""
    ); command
    (setq
      inc (1+ inc)
      ent cut
      outer (setq ent (entnext ent)); the outermost Region [first if multiple]
      inner (ssadd); initially empty selection set of inner Region(s)
    ); setq
    (while (setq ent (entnext ent)); internal Region(s)?
      (ssadd ent inner); put in selection set
    ); while
    (if (> (sslength inner) 0); were there internal Regions?
      (command "_.subtract" outer "" inner ""); outer keeps entity name
    ); if
    (setq outerobj (vlax-ename->vla-object outer))
    (write-line
      (strcat ;   <-------EDIT precision arguments in three (rtos) functions
        (itoa inc) "," ; Line number
        (rtos (setq area (vla-get-Area outerobj)) 2 3) "," ; Area
        (rtos (setq cogd (- (cadr UR) (cadr (vlax-get outerobj 'Centroid)))) 2 3) "," ; COG depth
        (rtos (* area cogd) 2 3)
      ); strcat
      file
    ); write-line
    (entdel outer)
  ); while [move Xline]
  (entdel cut)
  (close file)
  (princ)
); defun
EDIT the command name from "WHATEVER" to whatever you prefer, and see the lines marked  <-------EDIT  for other things you need to change to suit your setup and preferences.
It does not yet do the Table in the drawing, but it does the spreadsheet file, since I know more readily how to do that.  It's not difficult to make a Table and just link the .csv file -- I haven't looked into automating that.
It should work for shapes such as in your original image, but there could be configurations in which it would fail, particularly these possibilities:
A)  if the location at 1/2 unit below the top at the middle of the width is outside the perimeter object; or
B)  if anything crosses that location, so that the pick for the BOUNDARY command will be exactly on something.
Also, it relies on something I think is always true, but I'm not sure:  that if BOUNDARY results in more than one Region, the outermost of them is always the first one in drawing order.
But give it a try, for what it can do so far.
Kent Cooper, AIA
Message 7 of 28
rafael.bizarro
Thank you first of all for the effort! I am trying to use the routine but this error is resulting.
Message 8 of 28
Kent1Cooper
In AutoLisp, file path separators need to be either double backslashes or single forward slashes:
  file (open "C:/Users/Rafael/OneDrive/Backup Scalata/Arquivo/Utilidades/Lisps autocad/teste areacomprimida.csv" "w")
Kent Cooper, AIA
Message 9 of 28
rafael.bizarro
Now it worked but if the figure is in meters, it calculates only 2 points. I tried to put a figure in centimeters but it did almost 90,000 calculations.
Message 10 of 28
Kent1Cooper
It was written to work in plain drawing units.  Since everything in the original image was in terms of centimeters, I assumed the drawing unit is a centimeter.  If your drawing unit is really a meter, but you want things reported in centimeter terms, then some lines need to be changed:
      "_.move" cut "" "0,-0.01" ""
and
        (rtos (setq area (* (vla-get-Area outerobj) 1e4)) 2 3) "," ; Area
        (rtos (setq cogd (* (- (cadr UR) (cadr (vlax-get outerobj 'Centroid)) ) 100)) 2 3) "," ; COG depth
I hope that's all that needs to be changed [untested].
Kent Cooper, AIA
Message 11 of 28
rafael.bizarro
I made the changes but it's still doing a lot of calculations. More than 30,000 lines in excel. Here are the files I'm using.
Message 12 of 28
Kent1Cooper
Just to confirm:  That T shape is 2 meters [2 drawing units] wide and 1.95 meters tall?  And you want it checked at centimeter intervals?  That's 195 slices.
Kent Cooper, AIA
Message 13 of 28
Kent1Cooper
Something I missed before -- correct this line from 0.5 to 0.005:
    pickpt (list (/ (+ (car LL) (car UR)) 2) (- (cadr UR) 0.005)); 1/2 cm below top middle
so that the pick point for the BOUNDARY commands is between the top and the first slice level.  But I do wonder, with the Zoom level out where you see the whole shape, and 195 slices, whether that pick point is going to be seen correctly, being extremely close to the top edge.
Kent Cooper, AIA
Message 14 of 28
rafael.bizarro
Yes, correct
Message 15 of 28
Kent1Cooper
Try running it with Object Snap off.
Kent Cooper, AIA
Message 16 of 28
rafael.bizarro
You can set the first pick point to 5 centimeters from the top if helps
Message 17 of 28
Kent1Cooper
You mean the first slice level 5cm down?  But then at 1cm intervals continuing down?
Kent Cooper, AIA
Message 18 of 28
rafael.bizarro
Yes.
But i Ran without snap and worked fine.
Message 19 of 28
rafael.bizarro
Now i m having some issues with "." and "," from the data on the excel.
Some values "." is representing 000 separator and others "." represent ",".
Message 20 of 28
Kent1Cooper
Is there a setting in AutoCAD to report numbers without any thousands separators?
Kent Cooper, AIA
