Lisp for calculating geometric properties
rafael.bizarro
Message 1 of 28
rafael.bizarro
Good afternoon my friends. I really need a help to elaborate this LISP according to the step-by-step in the image below. I would be very grateful for your help. Thank you in advance.
Replies (27)
Message 21 of 28
rafael.bizarro
Message 22 of 28
rafael.bizarro
I couldn't find a way to remove these separators.
Message 23 of 28
Sea-Haven
I have read a csv create a table if you want it. But easier is make a table the 1st 3 rows heading, description, data etc then when you write line to csv just do a insertrows to table very easy.
; Example of how to create an Autocad Table
; By Alan H
(defun AHMaketable (/ colwidth numcolumns numrows objtable rowheight sp vgad vgao vgms)
(vl-load-com)
(setq sp (vlax-3d-point (getpoint "\nPick point for table")))
(Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq numrows 5)
(setq numcolumns 5)
(setq rowheight 2.5)
(setq colwidth 60)
(setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "DRAWING REGISTER")
(vla-settext objtable 1 0 "DRAWING NUMBER")
(vla-settext objtable 1 1 "DRAWING TITLE")
(vla-settext objtable 1 2 "C")
(vla-settext objtable 1 3 "D")
(vla-settext objtable 1 4 "E")
(vla-settext objtable 2 0 "1")
(vla-settext objtable 3 0 "2")
(vla-settext objtable 4 0 "3")
(command "_zoom" "e")
(princ)
(AHMaketable)
(princ "\n")
(setq n 2 txtht 45)
( AH:table_make 2 n txtht  400)
(setq objtable (vlax-ename->vla-object (entlast)))
would do the write line now do
(vla-insertrows objtable  (setq n (1+ n)) (* txtht  2.0) 1)
(vla-settext objtable (1+ n) 0 val1)
(vla-settext objtable (1+ n) 1 val2)
(vla-setrowheight objtable (1+n)  (* txtht 2.0))
This is not true code but example call (ahmaketable) 1st then the insertrows.
Oh yeah if table is huge make sure tableregenerate :vlax-false else will grind to a halt.
Message 24 of 28
rafael.bizarro
Could you help us get this Lisp right please?
Message 25 of 28
Sea-Haven
I am sure if you ask Kent nicely he will help you add the table part, then all the code is by 1 author and not bits pasted together. With conflicting variable names.
Message 26 of 28
rafael.bizarro
Kent, Could you add this routine to the LISP please?
Message 27 of 28
Kent1Cooper
Maybe later, after I have a chance to study it and understand what it is doing.  But I notice that the lower part calls for a function called  AH:table_make  which is not defined.  It can't be a typo that should be  AHMaketable , because the usage of  AH:table_make  supplies arguments which  AHMaketable  is not defined to take.
Kent Cooper, AIA
Message 28 of 28
Sea-Haven
Sorry cut bits out of a couple of programs, I have a default ah:maketable that I use and at some stage must have changed it.
It should be like
(defun ah:maketable ( numcolumns numrows colwidth rowheight  / sp curspace)
One buggy thing is that sometimes both Autocad and Bricscad lose objtable, so after making the initial table reset it again (setq objtable (vlax-ename->vla-object (entlast))) I do not know why it just stops working sometimes, the other is if doing a lot of insertrows, do (vla-put-regeneratetablesuppressed Objtable :vlax-true) and after populating the new rows do (vla-put-regeneratetablesuppressed Objtable :vlax-false) then it will draw the table. I have made tables with like 100 rows and it will just stop generating if you dont suppress the regen.
