Lisp for block preview next to count table
aharrisonF8JWH
aharrisonF8JWH
Hello, I have been trying to use Lee Macs Block counter so that my table has a preview of the block next to it, however I want to know if there is a lisp or way I can continue to use the CAD block table but it automatically places the block preview next to each item in the table.
With Lee Macs tool I am running into a problem because I want to select of all instances of certain blocks only within a selected area. For this I have placed a rectangle around each apartment, use count list- then click count in specified area- object- click the rectangle.  Use the block list to select the blocks I want included need a separate legend for certain blocks in each apartment. I prefer the block list rather than the hassle of clicking each individual block which I think I need to do for Lee Macs.
image below shows I know I can manually place block into each cell but this is tedious for multiple apartment typicals in multiple projects
Moshe-A
@aharrisonF8JWH  hi,
post your sample dwg (should include your blocks)
marko_ribar
See if this code can help you anyway...
https://www.cadtutor.net/forum/topic/85573-changing-all-block-attribute-values-together-like-a-norma...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Sea-Haven
