Changing views with AutoLISP
amacklinZE25K
amacklinZE25K
Hi so I'm an architecture intern and I have a pet project in 3d that I'm working on. I want to automate the rendering process of it. What I want to do is switch between all of my different views that I have setup via the cameras, and then render them out. I have a pretty beginner knowledge of AutoLISP
paullimapa
Not sure if code from this thread still works since it was designed for a much older version of AutoCAD but you can give it a try
Paul Li
IT Specialist
@The Office
amacklinZE25K
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
amacklinZE25K
This was my code just in case anyone else wants it
(defun c:bulkRend (/ viewNames renderPath renderFileName delay)
  ;; List of view names you want to render
  (setq viewNames '("view1" "view2" "view3"))
  ;; Loop through each view name and render
  (foreach viewName viewNames
    ;; Set the current view to the named view
    (setq renderPath (strcat "C:\\path\\" viewName ".png"))
    (command "._VIEW" "_r" viewName)
    ;; Start rendering pretty low quality
    (command "RENDER" "LOW" "RENDER" "800" "600" "Y" renderPath)
    ;; Delay between renders so my pc fans don't spin up to 100% you can remove
    (command "'delay" "5000")
  (princ) ;; Exit quietly
