Automatically labeling attributed to a fixed maximum repeating
DanieljL9MXY
Observer Observer
DanieljL9MXY
Observer
Observer
Hi there
Im currently looking to edit a lsp script im using to allow me insert blocks which will include an increasing attribute for each copy of the block up to a maximum value before resetting to the initial value and beginning the count again,
The current script im using updates the attribute for each copy but does not reset at a maximum instead counting on to infinity, how would i be able to edit this script to reset at a chosen value
https://www.lee-mac.com/autolabelattributes.html
Sea-Haven
Are you using Lee's lisp ? If so which one.
There is plenty of insert block and increment lisps out there, for me I add look for last number used 1st if none then number is 1, re reset number should be a simple (If (> num 100)(setq num 1)) in the code.
Post a dwg with your block.
DanieljL9MXY
Observer
Observer
Thanks Sea Haven
Ive since spoken to Lee himself directly and have been able to revise the code to include a counting modulus to act in the way youve described below 🙂
Kent1Cooper
@Sea-Haven wrote:
.... should be a simple (If (> num 100)(setq num 1)) ....
If starting at 1 and if it should be reset to 1 after reaching the maximum value, here's another approach.  It does not involve an (if) function that needs to run a test every time, overtly comparing the current value to the maximum to decide whether it's time to reset.
(setq maxint (getint "\nMaximum value: "))
(setq val 0); initial pre-first-value
Then, each time the incremented number is called for, do this:
(setq val (1+ (rem val maxint)))
to return the next integer up, or back to 1 when the maximum has been reached.
If I set the maximum to 5, then:
1
(setq val (1+ (rem val maxint))) ; ... same again
2
3
4
5
1
2
... etc. ...
Kent Cooper, AIA
