LISP error
LISP error
Message 1 of 8
LISP error
Hi all,
I have problem to run this lisp on AUTOCAD 2017
Command: ISOBLOCK
>>>...Pick a block...>>>:
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Replies (7)
Message 2 of 8
roland.r71
@Anonymous wrote:
Hi all,
Command: ISOBLOCK
I see a few (non fatal) 'errors' with your lisp:
1: the script potentially ruins user settings, by simple setting cmdecho to 1, instead of restoring the setting it had at startup.
 - Example: (setq startecho (getvar "cmdecho")) at the start & (setvar "cmdecho" startecho) at the end to restore it.
2: inside the *error* function there's a (load "flattensup.lsp") - you should REALY avoid loading scriptfiles inside functions, especially the *error* function.
3: as a lisp file is processed line by line, you should put the (vl-load-com) at the top of the script file, not the bottom, to avoid problems.
4: the (*error* "") call at the end looks a bit odd... (and obsolete)
...as for the error message, it says you can not use a (command "bladibla") call inside the *error* function.
now, it doesn't inside this script ... but there's probably one or more inside the "flattensup.lsp" file which gets (re)loaded there... (can't check as you did not attach that file...)
Message 3 of 8
;; Command Name - IsoBlock
;; Routine For Transforming a Block to Isometric
;; By WizMan_07Feb10
;; Version 1.0 - 11May09
;; Version 1.1 - 06Feb10 - Added Reverse Option and Flatten(Express)
;; Version 1.2 - 07Feb10 - Fixed DText Rotation inside block(by SEANT)
(defun c:isoblock (/ blok_ent
counter ent_data
ent_pt i
sub_func *error*
blk_name midtbox
midtxt reverseflag
rot tbox
(defun to_southwest (ent_name base_pt / obj)
(vla-TransformBy
(setq obj (vlax-ename->vla-object ent_name))
(vlax-tmatrix
(list
(list (/ (sqrt 2.) 2.) (- (/ (sqrt 2.) 2.)) 0. 0.)
(list (/ (sqrt (/ 2. 3.)) 2.)
(sqrt (/ 2. 3.))
0.
(list (- (/ (sqrt 3.) 3.))
(/ (sqrt 3.) 3.)
0.
(list 0. 0. 0. 1.)
(vla-move obj
(vlax-3d-point
(trans (cdr (assoc 10 (entget ent_name))) ent_name 0)
(vlax-3d-point base_pt)
(defun to_southeast (ent_name base_pt / obj)
(vla-TransformBy
(vlax-tmatrix
(list
(list (/ (sqrt 2.) 2.) (/ (sqrt 2.) 2.) 0. 0.)
(list (- (/ (sqrt (/ 2. 3.)) 2.))
(sqrt (/ 2. 3.))
0.
(list (/ (sqrt 3.) 3.)
(/ (sqrt 3.) 3.)
0.
(list 0. 0. 0. 1.)
(vla-move obj
(vlax-3d-point
(defun to_front (ent_name base_pt / obj)
(vla-TransformBy
(vlax-tmatrix
(list
(list 1. 0. 0. 0.)
(list 0. 0. 1. 0.)
(list 0. 1. 0. 0.) ;mirrored
(list 0. 0. 0. 1.)
(vla-move obj
(vlax-3d-point
(defun to_front_southwest (ent_name base_pt / obj)
(to_front ent_name base_pt)
(to_southwest ent_name base_pt)
(defun to_front_southeast (ent_name base_pt / obj)
(to_southeast ent_name base_pt)
(defun dtr (var)
(* PI (/ var 180.0))
(defun fix_txt (blk oblang / ins)
(vlax-for
obj
(vla-item (vla-get-Blocks doc) (cdr (assoc 2 (entget blk))))
(if (eq "AcDbText" (vla-get-Objectname obj))
(progn
(Setq ins (vlax-get obj 'insertionpoint))
(vla-put-upsidedown obj 0)
(vla-put-ObliqueAngle obj (dtr oblang))
(vlax-put obj 'insertionpoint ins)
(vla-update (vlax-ename->vla-object (entlast)))
(defun *error* (msg)
(if blok_ent
(progn
(acet-flatn (ssadd blok_ent (ssadd)) nil)
(cond ((= sub_func (quote to_front_southwest))
(fix_txt (entlast) 30)
((= sub_func (quote to_front_southeast))
(fix_txt (entlast) 330)
(t nil)
(if reverseflag
(vlax-for
obj
(vla-item (vla-get-Blocks doc) blk_name)
(vla-rotate obj (vlax-3d-point midtxt) pi)
(setq reverseflag nil)
(and doc (vla-endundomark doc))
(setvar 'cmdecho 1)
(setq doc (vla-get-activedocument
(vlax-get-acad-object)
(vla-EndUndoMark doc)
(vla-StartUndoMark doc)
(setvar 'cmdecho 0)
(if (setq blok_ent (car (entsel "\n>>>...Pick a block...>>>: ")))
(progn
(setq ent_data (entget blok_ent))
(setq ent_pt (cdr (assoc 10 ent_data)))
(setq blk_name (cdr (assoc 2 ent_data)))
(to_southwest blok_ent ent_pt)
(setq counter 1)
(while (or (= (setq i (strcase
(getstring
"\rPress [SpaceBar] to Toggle View, [R]everse or Press any Letter to exit: "
(= i "R")
(if (/= i "R")
(progn
(if blok_ent
(vla-delete (vlax-ename->vla-object blok_ent))
(setq sub_func
(nth counter
'(to_southwest
to_southeast
to_front_southwest
to_front_southeast
(entmake ent_data)
(setq blok_ent (entlast))
(if reverseflag
(vlax-for
obj
(cdr (assoc 2 (entget blok_ent)))
(progn
(vla-update (vlax-ename->vla-object blok_ent))
((eval sub_func) blok_ent ent_pt)
(if (< counter 3)
(setq counter (1+ counter))
(setq counter 0)
(if (not reverseflag)
(progn
(setq reverseflag t)
(setq rot (vla-get-rotation (vlax-ename->vla-object blok_ent)))
(vla-put-rotation
(+ rot pi)
(vlax-for
obj
(vla-item (vla-get-Blocks doc) (cdr (assoc 2 (entget blok_ent))))
(progn
(setq ins (vlax-get obj 'insertionpoint))
(setq tbox (textbox (entget (vlax-vla-object->ename obj))))
(setq midtbox (mapcar '/
(mapcar '+ (car tbox) (cadr tbox))
'(2. 2. 2.)
(setq midtxt (mapcar '+ ins midtbox))
(*error* "")
(princ)
(vl-load-com)
(prompt
"\n>>>...IsoBlock.lsp is now loaded. Type 'IsoBlock' to start ...<<<"
) ;_ prompt
(princ)
;;WIZ_07FEB10
Message 4 of 8
previously it worked on autocad 2016 & 2017. Then suddenly i got an error yesterday when i tried to run the lisp.
Please help me to edit this lisp to run on this new environment. thanks
Message 5 of 8
Update the autocad with july2017 patch. Lisp successfully run but still getting the error messages:
Anyway by updating the autocad solved this problem.
Merci
Message 6 of 8
roland.r71
Merci
Good, but not entirely...
As i said before, the error message is telling you using a (command "") call is not allowed inside the *error* function.
I checked a bit more into it and found the following:
The flattensup.lsp file is a part of ACETutil (AutoCAD Express Tools) and as i guessed before... it contains several (command "") calls.
This means the code inside your *error* function is NOT executed correctly.
The line:
Is actually invoking a function containing the (command "") calls, crashing the *error* function.
Tip: Post your lisp code using the "Insert Code" button. It will keep any leading spaces, keeping the code structured & readable.
Message 7 of 8
Noted. thanks Roland
