mtext height change, code error
; mtext height change
(defun c:chgtxth ()
  (setq n 0 )
  (setq sstxt (ssget "_X" '((0 . "MTEXT")(40 . 500))))
  (repeat (sslength sstxt)
    (setq en (ssname sstxt n))
    (setq endata (entget en))
    (setq entype (cdr (assoc 40 endata)))
    (if (= entype 500)
      (txt_h)
      );end if
    (setq n (1+ n))
    ); end repeat
  (prin1)
  ); defun
  (defun txt_h()
  (setq old_h (assoc 40 endata))
    (setq new_h (cons 40 600))
    (setq endata (subst new_h old_h endata))
    (entmod endata)
        ); sub-defun
  (prompt "change mtext height")
  (prin1)
Hello, experts,
The code I wrote for changing mtext height from 500 to 600 always gave me error message; can anyone help me to identify the mistakes?
thanks,
dbroad
What is your error? It seems to work fine here.  It could certainly be improved but works.
Architect, Registered NC, VA, SC, & GA.
Ranjit_Singh
What error message do you get? It works fine at my end. Although I would recommend localizing the variables and passing endata to the txt_h function
(defun c:chgtxth  (/ en endata entype n sstxt)
  (setq n 0)
  (setq sstxt (ssget "_X" '((0 . "MTEXT") (40 . 500))))
    (if (= entype 500)
      (txt_h endata)) ;end if
    (setq n (1+ n))) ; end repeat
  (prin1)) ; defun
(defun txt_h  (endata / new_h old_h)
  (entmod endata)) ; sub-defun
(prin1)
pbejse
hifrank001 wrote:
...The code I wrote for changing mtext height from 500 to 600 always gave me error message; can anyone help me to identify the mistakes?
thanks,
Silly question (coming from me) < don't take it the wrong way > but does the drawing even have an MTEXT with 500 height??
If none was found, you will get this because of the way the code is written | from (sslength ssttxt)
; error: bad argument type: lselsetp nil
if so,
Add
(if (setq sstxt (ssget "_X" '((0 . "MTEXT") (40 . 500))))
and and closing parenthesis.
HTH
thanks, pBe; it is the error message I got; but the plan does have 500 mtext. see attached.
Thanks, people.
I found the mistake but it is not from the code.
pbejse
Thanks, people.
I see, one more reason for that is when the value for variable n is out of range, but it clearly defined on your code.
But then again, if you leave your code as it stands now [ no if statement ] , second time you ran the command it will again produce that error.
Sit back and think , what did you do differently when the error pops up again on the command line.
EDIT: I see you got it figured out then.
MORE EDIT: I would suggest you use VLIDE when debugging your code, easier to spot the errors like the one you had.
Cheers
