Lisp doesn't work until I run another lisp
alex_mcturk
alex_mcturk
I am having a problem with my lisp,
it gives me the error message
"error: bad argument type: stringp nil"
But I run another lisp an "Old" version
(uses a different defun name)
after I use that code, my new code works fine every time?
what could be doing this ?
ВeekeeCZ
Probably some global variable...
Moshe-A
@alex_mcturk  hi,
This error arise when passing a nil variable (or an invalid) to a function that expect string
example:
(strcat "abc" nil)
why it works after you load and old lisp?
maybe a function (with same name) but a call with right variable 😀
Moshe
