lisp to check if the filter group exist
S_S_SS
Message 1 of 10
S_S_SS
Hello every one
I search for a lisp code to check
if the filter group with name "formwork" exist make a list of the layers inside this filter group
ifnot exist make a list of the layers in the DWG
i've made this trial the issue is about the filter group
(defun c:GetLayerList ()
  (setq layerList '()) ; Initialize an empty list for layers
  (setq layerTable (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) ; Get the Layers collection
  ; Try to find the "Formwork" filter group
  (setq filterGroupExists nil)
  (setq formworkLayers '())
  ; Check if a group filter exists
  (vl-cmdf "_.-LAYER" "_FILTER" "_Edit" "Formwork" "_List" "_exit" "")
  (if (= (getvar "CMDNAMES") "LAYER")
    (progn
      (setq filterGroupExists T)
      (vl-cmdf "_List")
      (while (> (getvar "CMDACTIVE") 0)
        (command "")
      ; Collect layers from the "Formwork" filter (assuming output goes to command history)
      (setq formworkLayers (read (vl-string-trim "\n" (getvar "CMDLINE"))))
  ; If the group exists, use its layers; otherwise, get all layers
  (if filterGroupExists
    (setq layerList formworkLayers)
    (vlax-for layer layerTable
      (setq layerList (cons (vla-get-name layer) layerList)) ; Add layer names to the list
  ; Return the layer list
  layerList
and see the attached dwg
thanks in advance
Replies (9)
Message 2 of 10
ВeekeeCZ
Here's your starting point...
(defun :LayerFilterList (typ / obj dict item ent def N LayerITEMS Layerobj Layernams lst)
  ;; typ: properties/group/group
  (setq typ (cond ((= typ "properties")	"ACLYLAYERFILTER")
                  ((= typ "group") 	"ACLYLAYERGROUP")
                  ((= typ "both")	"ACLYLAYERFILTER,ACLYLAYERGROUP")
  (if (and (setq obj (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
	   (= (vla-get-hasextensiondictionary obj) :vlax-true)
	   (setq obj (vla-GetExtensionDictionary obj))
	   (not (vl-catch-all-error-p
		  (setq dict (vl-catch-all-apply 'vla-item (list obj "AcLyDictionary"))))))
    (vlax-for itm dict
      (if (and (setq ent (vlax-vla-object->ename itm))
	       (setq def (entget ent))
	       (= (type (cdr (assoc 1 def))) 'STR)
	       (wcmatch (strcase (cdr (assoc 1 def))) typ)
	       (= (type (setq name (cdr (assoc 300 def)))) 'STR)
        (setq lst (cons name lst)))))
  lst)
Message 3 of 10
cadffm
Hint: Posting issue:
Additional information for others: It's for Top-Level Filters only (not for nested filters)
Sebastian
Message 4 of 10
Sea-Haven
Did a google and found some code just rearranged so only look for existing layer Filter. Thanks to PBE & Gile
; Original code get or import layer filters by PBE
; shortened to just check does layer filter exist Jan 2025
;;; GetItem (gile)
;; Returns the item vla-object if found in the collection
;;; Arguments
;;; col: a collection (vla-object)
;;; name: the object name (string) or its index (integer)
;;; Return: the vla-object or nil
(defun GetItem (col name / obj)
  (vl-catch-all-apply
    (function (lambda () (setq obj (vla-item col name))))
  obj
(setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq layerDict
     (vla-getExtensionDictionary (vla-get-Layers *acdoc*))
(setq filterlist '())
(setq layerFilters (GetItem layerDict "ACAD_LAYERFILTERS"))
(vlax-for f layerFilters
(setq filterList (cons (vla-get-Name f) filterList))
(if (member "Formwork" filterlist)
  (alert "found")
  (alert "not found")
Message 5 of 10
ВeekeeCZ
Thanks - that must have been autocorrect spelling... wtf!?.
This one work with nested filter too... but it's not adjusted to work with groups.
(defun :LayerFilterList (/ :SubFilterList)
  ; sub returns list of main filter and sub filters right behind
  (defun :SubFilterList (dict / ent lst)
    (foreach ent (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 350)) dict))
      (setq lst (append lst
			(cons ent (if (assoc 360 (entget ent))
				    (:SubFilterList (entget (cdr (assoc 360 (entget (cdr (assoc 360 (entget ent)))))))))))))
    lst)
  (mapcar '(lambda (x) (cdr (assoc 300 (entget x))))
	  (:SubFilterList (dictsearch
			      (vla-getextensiondictionary
				(vla-get-layers
				    (vlax-get-acad-object)))))
			    "ACLYDICTIONARY")
Message 6 of 10
Moshe-A
@S_S_SS  hi,
This one is based on mr Lee Mac (LM:grouplayerfilters) function.
enjoy
Moshe
(defun ContentOfLayerGroup (lgName)
   (   (lambda ( foo ) (foo (entget (cdr (assoc 330 (entget (tblobjname "layer" "0")))))))
       (lambda ( enx / flag dic itm rtn)
           (and (setq dic (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") enx))))
                (setq dic (cdr (assoc -1  (dictsearch dic "aclydictionary"))))
                (while (and
			 (not flag)
			 (setq itm (dictnext dic (not itm)))
                    (if (and
			  (= "AcLyLayerGroup" (cdr (assoc 1 itm)))
			  (eq (strcase (cdr (assoc 300 itm))) (strcase lgName))
		      (setq rtn
			     (vl-remove-if
			      'not
		              (mapcar
			        (function
			          (lambda (e)
			            (if (= (car e) 330)
			              (cdr (assoc 2 (entget (cdr e))))
  		                (cdr (member (assoc 300 itm) itm))
		              ); mapcar
		             ); vl-remove-if
		      flag t); setq
                    ); if
                ); while
           ); and
	 rtn
       ); lambda
   ); wrap list
); MA:ContentOfLayerGroup
(defun c:GetLayerList (/ layfltr tbl lst)
 (if (setq layfltr (ContentOfLayerGroup "formwork"))
  (princ layfltr)
  (progn
   (while (setq tbl (tblnext "layer" (not tbl)))
    (setq lst (cons (cdr (assoc '2 tbl)) lst))
   (princ lst)
  ); progn
 ); if
 (princ)
Message 7 of 10
S_S_SS
Thanks sir
this works correctly
Message 8 of 10
S_S_SS
Hello sir
I need additional issue
I need to make the arrangement of the layers is as the ID arrangement of the layers in the AutoCAD
it change this arrangement and this makes incorrect things with my general code
Message 9 of 10
Moshe-A
@S_S_SS  hi,
if by saying 'arrangement of the layers' you mean sorting then you can do something like this:
(vl-sort layfltr '<) ; for Ascending Sort
or
(vl-sort layfltr '>) ; for Decending Sort
where layfltr is the list returned from (ContentOfLayerGroup) function
Moshe
Message 10 of 10
S_S_SS
thanks it works correctly
