Lisp coordinate grid - from viewport
Edwin.Saez
Advisor Advisor
Message 1 of 61
Edwin.Saez
hi,
someone could help me with some routine to generate a coordinate grid by selecting a "viewport" and that the grid is drawn in the model space.
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
Replies (60)
Message 21 of 61
Edwin.Saez
Any comments please help me to finish this lisp that I need.
Thank you for your comments and suggestions.
Edwin Saez
Message 22 of 61
CADaSchtroumpf
Perhaps?
(vl-load-com)
(defun l-coor2l-pt (lst flag / )
		(if lst
				(cons (list (car lst) (cadr lst) (if flag (caddr lst) 0.0))
						(l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag)
(defun convert_str2mil (str2cnv / l_str n l_nw)
	(setq l_str (reverse (vl-string->list str2cnv)) n 1)
	(while l_str
		(if (zerop (rem n 3))
			(setq l_nw (cons 32 (cons (car l_str) l_nw)))
			(setq l_nw (cons (car l_str) l_nw))
		(setq l_str (cdr l_str) n (1+ n))
	(vl-list->string l_nw)
(defun c:ViewPort2Grid ( / js ent dxf_ent pt_v id_vp l h lst_pt js_obj nw_pl unit_draw AcDoc Space UCS save_ucs WSC nw_style f_pat ob_lst_pt dlt pt_ins format_scale ech htx nw_pl_out hatch lst_pt str ori_txt nw_txt pt_ins)
	(setvar "CMDECHO" 0)
	(if (eq (getvar "CTAB") "Model") (setvar "TILEMODE" 0))
	(command "_.PSPACE")
	(princ "\nSelect a viewport: ")
	(while
		(null
			(setq js
				(ssget "_+.:E:S:L"
					(list
						'(0 . "VIEWPORT")
						'(67 . 1)
						(cons 410 (getvar "CTAB"))
						'(-4 . "!=")
						'(69 . 1)
	(setq
		pt_v (cdr (assoc 10 (setq dxf_ent (entget (setq ent (ssname js 0))))))
		id_vp (cdr (assoc 69 dxf_ent))
		l (cdr (assoc 40 dxf_ent))
		h (cdr (assoc 41 dxf_ent))
		lst_pt
		(list
			(list (- (car pt_v) (* 0.5 l)) (- (cadr pt_v) (* 0.5 h)) 0.0)
			(list (+ (car pt_v) (* 0.5 l)) (- (cadr pt_v) (* 0.5 h)) 0.0)
			(list (+ (car pt_v) (* 0.5 l)) (+ (cadr pt_v) (* 0.5 h)) 0.0)
			(list (- (car pt_v) (* 0.5 l)) (+ (cadr pt_v) (* 0.5 h)) 0.0)
		js_obj (ssadd)
	(entmakex
		(vl-list*
			(cons 0 "LWPOLYLINE")
			(cons 100 "AcDbEntity")
			(cons 67 1)
			(cons 100 "AcDbPolyline")
			(cons 90 (length lst_pt))
			(cons 70 1)
			(mapcar '(lambda (p) (cons 10 p)) lst_pt)
	(ssadd (setq nw_pl (entlast)) js_obj)
	(command "_.MSPACE")
	(setvar "CVPORT" id_vp)
	(command "_.CHSPACE" js_obj "")
	(setq unit_draw 1000)
	(setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
	(vla-StartUndoMark AcDoc)
	(setq
		Space
		(if (eq (getvar "CVPORT") 1)
			(vla-get-PaperSpace AcDoc)
			(vla-get-ModelSpace AcDoc)
		UCS (vla-get-UserCoordinateSystems AcDoc)
		save_ucs
		(vla-add UCS
			(vlax-3d-point '(0.0 0.0 0.0))
			(vlax-3d-point (getvar "UCSXDIR"))
			(vlax-3d-point (getvar "UCSYDIR"))
			"CURRENT_UCS"
	(vla-put-Origin save_ucs (vlax-3d-point (getvar "UCSORG")))
	(setq WCS (vla-add UCS (vlax-3d-Point '(0.0 0.0 0.0)) (vlax-3d-Point '(1.0 0.0 0.0)) (vlax-3d-Point '(0.0 1.0 0.0)) "TEMP_WCS"))
	(vla-put-activeUCS AcDoc WCS)
	(if (not (tblsearch "STYLE" "A-Romans"))
		(progn
			(setq nw_style (vla-add (vla-get-textstyles AcDoc) "A-Romans"))
			(mapcar
				'(lambda (pr val)
					(vlax-put nw_style pr val)
				(list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
				(list "ROMANS.SHX" 0.0 0.0 0.8 0.0)
	(if (not (tblsearch "LAYER" "A-Grilla"))
		(vlax-put (vla-add (vla-get-layers AcDoc) "A-Grilla") 'color 7)
	(if (not (findfile "REPQUADISO.pat"))
		(progn
			(setq f_pat (open (strcat (getvar "ROAMABLEROOTPREFIX") "support\\REPQUADISO.pat") "w"))
			(write-line "*REPQUADISO,Repere du quadrillage lambert" f_pat)
			(write-line "0, 0,0, 0,1" f_pat)
			(write-line "90, 0,0, 0,1" f_pat)
			(close f_pat)
	(if (not (tblsearch "BLOCK" "A-NORTE"))
		(foreach n
					(0 . "BLOCK")
					(8 . "0")
					(2 . "A-NORTE")
					(70 . 0)
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
					(10 0.0 0.0 0.0)
					(0 . "LWPOLYLINE")
					(100 . "AcDbEntity")
					(67 . 0)
					(410 . "Model")
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
					(100 . "AcDbPolyline")
					(90 . 13)
					(70 . 1)
					(38 . 0.0)
					(39 . 0.0)
					(10 0.00625 -0.001)
					(40 . 0.0025)
					(41 . 0.0025)
					(42 . 0.0)
					(91 . 0)
					(10 0.0045 -0.001)
					(40 . 0.00125655)
					(41 . 0.00125655)
					(42 . 0.0)
					(91 . 0)
					(10 0.00112828 0.00479937)
					(40 . 0.00130141)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.0005 0.00713)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.0005 0.00125)
					(40 . 0.0025)
					(41 . 0.0025)
					(42 . 0.0)
					(91 . 0)
					(10 -0.0005 0.00125)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -0.0005 0.00713)
					(40 . 0.0)
					(41 . 0.00130141)
					(42 . 0.0)
					(91 . 0)
					(10 -0.00112828 0.00479937)
					(40 . 0.00125655)
					(41 . 0.00125655)
					(42 . 0.0)
					(91 . 0)
					(10 -0.0045 -0.001)
					(40 . 0.0025)
					(41 . 0.0025)
					(42 . 0.0)
					(91 . 0)
					(10 -0.00625 -0.001)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -0.00625 0.00025)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -1.20856e-013 0.011)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.00625 0.00025)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(210 0.0 0.0 1.0)
					(0 . "LWPOLYLINE")
					(67 . 0)
					(410 . "Model")
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
					(90 . 11)
					(70 . 1)
					(38 . 0.0)
					(39 . 0.0)
					(10 0.0025 -0.008875)
					(40 . 0.00225)
					(41 . 0.00225)
					(42 . 0.0)
					(91 . 0)
					(10 0.00125 -0.008875)
					(40 . 0.00137185)
					(41 . 0.00137185)
					(42 . 0.0)
					(91 . 0)
					(10 -0.000564075 -0.0065167)
					(40 . 0.00144903)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -0.00125 -0.0045)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -0.00125 -0.008875)
					(40 . 0.00225)
					(41 . 0.00225)
					(42 . 0.0)
					(91 . 0)
					(10 -0.0025 -0.008875)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -0.0025 -0.00225)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 -0.00125 -0.00225)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.00125 -0.0055)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.00125 -0.00225)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.0025 -0.00225)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(210 0.0 0.0 1.0)
					(0 . "ENDBLK")
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
			(entmake n)
	(setq
		nw_pl (vlax-ename->vla-object nw_pl)
		ob_lst_pt (vlax-get nw_pl 'coordinates)
		pt_ins (list (car ob_lst_pt) (cadr ob_lst_pt))
		format_scale (/ 1.0 (vlax-get (vlax-ename->vla-object ent) 'CustomScale))
		ech (* unit_draw format_scale)
		htx (/ ech 500.0)
	(vla-put-layer nw_pl "A-Grilla")
	(vla-Offset nw_pl (* htx 2.5))
	(setq nw_pl_out (vlax-ename->vla-object (entlast)))
	(setvar "HPORIGINMODE" 0)
	(setvar "HPORIGIN" '(0.0 0.0))
	(setq hatch (vla-AddHatch Space acHatchPatternTypeCustomDefined "REPQUADISO" :vlax-True))
	(vlax-invoke hatch 'AppendOuterLoop (list nw_pl))
	(vla-put-patternscale hatch (/ ech 10.0))
	(vla-put-patternangle hatch 0.0)
	(vla-put-layer hatch "A-Grilla")
	(vla-put-color hatch 8)
	(vla-evaluate hatch)
	(setq lst_pt
		(l-coor2l-pt
			(vlax-invoke
				hatch
				'IntersectWith
				nw_pl
				acExtendThisEntity
			T
	(foreach el lst_pt
		(cond
			((or (equal (rem (car el) (/ ech 10.0)) (/ ech 10.0) 1E-8) (equal (rem (car el) (/ ech 10.0)) 0.0 1E-8))
				(setq
          str (strcat (chr 160) "E " (convert_str2mil (rtos (car el) 2 0)) (chr 160))
          ori_txt (* pi 0.5)
          dlt (polar el pi htx)
			((or (equal (rem (cadr el) (/ ech 10.0)) (/ ech 10.0) 1E-8) (equal (rem (cadr el) (/ ech 10.0)) 0.0 1E-8))
				(setq
          str (strcat (chr 160) "N " (convert_str2mil (rtos (cadr el) 2 0)) (chr 160))
          ori_txt 0.0
          dlt (polar el (* pi 0.5) htx)
			(T (setq str nil ori_txt nil))
		(cond
			((and dlt str ori_txt)
				(setq nw_txt (vla-AddMText Space (vlax-3d-point dlt) (* 1.25 htx) str))
				(vla-put-layer nw_txt "A-Grilla")
				(vla-put-StyleName nw_txt "A-Romans")
				(vla-put-AttachmentPoint nw_txt 7)
				(vla-put-InsertionPoint nw_txt (vlax-3d-point (vlax-curve-getClosestPointTo nw_pl dlt T)))
				(vla-put-Rotation nw_txt ori_txt)
				(vla-put-Height nw_txt (* 1.25 htx))
				(vla-put-Width nw_txt 0.0)
				;(vla-put-BackgroundFill nw_txt -1)
				(if (> (vlax-safearray-get-u-bound (vlax-variant-value (vla-IntersectWith nw_pl_out nw_txt acExtendNone)) 1) 0)
					(progn
						(vla-put-AttachmentPoint nw_txt 9)
						(vla-put-TextString nw_txt (strcat str "."))
	(vla-delete nw_pl_out)
	(setq pt_ins (polar pt_ins (+ (* pi 0.25) (angle (list (car ob_lst_pt) (cadr ob_lst_pt)) (list (caddr ob_lst_pt) (cadddr ob_lst_pt)))) (* htx 10)))
	(setq nw_txt (vla-AddText Space (strcat " Scale 1/" (rtos ech 2 0)) (vlax-3d-point pt_ins) (* 2 htx)))
	(vla-put-Alignment nw_txt acAlignmentMiddleLeft)
	(vla-put-Rotation nw_txt (angle (list (car ob_lst_pt) (cadr ob_lst_pt)) (list (caddr ob_lst_pt) (cadddr ob_lst_pt))))
	(vla-put-TextAlignmentPoint nw_txt (vlax-3d-point pt_ins))
	(initget 9)
	(setq pt_ins (getpoint "\nGive insertion point of North: "))
	(entmakex
		(vl-list*
			(cons 0 "INSERT")
			(cons 67 0)
			(cons 410 "Model")
			(cons 8 "GRID")
			(cons 100 "AcDbBlockReference")
			(cons 2 "A-NORTE")
			(cons 10 pt_ins)
			(cons 41 ech)
			(cons 42 ech)
			(cons 43 ech)
			(cons 50 0.0)
			(cons 70 0)
			(cons 71 0)
			(cons 44 0.0)
			(cons 45 0.0)
			(list (cons 210 (list 0.0 0.0 1.0)))
	(vl-list*
		(cons 0 "INSERT")
		(cons 100 "AcDbEntity")(cons 210 (list 0.0 0.0 1.0))
	(and save_ucs (vla-put-activeUCS AcDoc save_ucs))
	(and WCS (vla-delete WCS) (setq WCS nil))
	(vla-EndUndoMark AcDoc)
	(setvar "CMDECHO" 1)
	(prin1)
Message 23 of 61
Edwin.Saez
@CADaSchtroumpf,
The texts are not dating with background?
The texts of the East side at the end come with a (.)
Is the only thing that would fail to solve so that it is ready at last.
I really appreciate your help. Smiley Very HappySmiley Very Happy
Edwin Saez
Message 24 of 61
CADaSchtroumpf
Uncomment the line:
Is the solution that i have find to force (chr 160) at end of the text, if not put a dot the (chr 160) (space forced) is not taken in consideration and text glue to the line and cannot be read correctly.
If you want test, comment the line:
Message 25 of 61
Edwin.Saez
@CADaSchtroumpf,
I have 1 question, why does autocad force the text background mask to value 1.50?
Lisp works fine, but could you have a text mask with value 1?
The texts come with 1.50 of text mask, which is the default value of autocad.
Eh regenerated the drawing and always kept with a text mask of 1.50.
I got a lisp that generates the ball but it only works from the model, but the texts do not stick to the extremes. Maybe you can find the solution within the lisp.
Edwin Saez
Message 26 of 61
Edwin.Saez
@CADaSchtroumpf,
I encountered an error while executing the lisp.
When the view is rotated, the grid is not generated and the following error is displayed:
Select a viewport:
Select objects:
Invalid point.
; error: Function cancelled
Set the TARGET viewport active and press ENTER to continue.: Set the TARGET viewport active and press ENTER to continue.: Set the TARGET viewport active and press ENTER to continue.: Set the TARGET viewport active and press ENTER to continue.:
1 object(s) changed from PAPER space to MODEL space.
Objects were scaled by a factor of 0.5 to maintain visual
appearance.
Edwin Saez
Message 27 of 61
CADaSchtroumpf
edwin.saez.jamanca a écrit :
@CADaStroumph,
Select a viewport:
Select objects:
Invalid point.
appearance.
Try with change (line 69)
by
(command "_.CHSPACE" js_obj "" (if (> id_vp 2) ""))
Message 28 of 61
Edwin.Saez
@CADaSchtroumpf,
Thanks for all the help.
You can not solve the text mask at value 1. it was always defaulted to 1.5.
But in general I can already use the lisp well.
thanks for everything.
Edwin Saez
Message 29 of 61
CADaSchtroumpf
You can try to add after line 359 a new line with:
 (entmod (subst '(45 . 1) (assoc 45 (entget (entlast))) (entget (entlast))))
Message 30 of 61
mihai_bantas
Hello, great job with the code,  can you help me with a problem. I attached a DWG to my request. Thanks
Message 31 of 61
CADaSchtroumpf
I am surprised at the request !!!
To have the north oriented as presented and to write the N in the sense of the east ...
But if you really want to do this, then invert lines 328 and 335 to have first:
and then:
Message 32 of 61
mihai_bantas
hi, i made the changes ... but i want to change with the value of the point.
As in the example presented  (dwg) with green cloud.
Have a nice daySmiley Tongue
Message 33 of 61
CADaSchtroumpf
I not sure to understand, but if you want dim a new grid, you can't move the old grid, you must erase the first and execute the lisp again.
The texte generated is static, no dynamic if you move it, it's false.
Message 34 of 61
mihai_bantas
Hy...(i want to work in coordinate system STEREOGRAFIC70, which has the reversed coordinates of the point) i change UCS to XY axe fom YX (acad standard) axe...and it worked. I think it's a UCS problem.
you can temporarily change the ucs on XY until inserting the North block....
Message 35 of 61
Automohan
Now is this the updated lisp!!!
(vl-load-com)
		(if lst
	(while l_str
	(while
		(null
			(setq js
				(ssget "_+.:E:S:L"
					(list
						'(0 . "VIEWPORT")
						'(67 . 1)
						'(-4 . "!=")
						'(69 . 1)
	(setq
		lst_pt
		(list
		js_obj (ssadd)
	(entmakex
		(vl-list*
			(cons 67 1)
			(cons 70 1)
	(setq
		Space
		save_ucs
		(vla-add UCS
			"CURRENT_UCS"
		(progn
			(mapcar
				'(lambda (pr val)
		(progn
			(close f_pat)
		(foreach n
					(0 . "BLOCK")
					(8 . "0")
					(2 . "A-NORTE")
					(70 . 0)
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
					(10 0.0 0.0 0.0)
					(0 . "LWPOLYLINE")
					(67 . 0)
					(410 . "Model")
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
					(90 . 13)
					(70 . 1)
					(38 . 0.0)
					(39 . 0.0)
					(10 0.00625 -0.001)
					(40 . 0.0025)
					(41 . 0.0025)
					(42 . 0.0)
					(91 . 0)
					(10 0.0045 -0.001)
					(40 . 0.00125655)
					(41 . 0.00125655)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.00130141)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.0005 0.00713)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(10 0.0005 0.00125)
					(40 . 0.0025)
					(41 . 0.0025)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.00130141)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.00125655)
					(41 . 0.00125655)
					(42 . 0.0)
					(91 . 0)
					(10 -0.0045 -0.001)
					(40 . 0.0025)
					(41 . 0.0025)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(210 0.0 0.0 1.0)
					(0 . "LWPOLYLINE")
					(67 . 0)
					(410 . "Model")
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
					(90 . 11)
					(70 . 1)
					(38 . 0.0)
					(39 . 0.0)
					(40 . 0.00225)
					(41 . 0.00225)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.00137185)
					(41 . 0.00137185)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.00144903)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.00225)
					(41 . 0.00225)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(40 . 0.0)
					(41 . 0.0)
					(42 . 0.0)
					(91 . 0)
					(210 0.0 0.0 1.0)
					(0 . "ENDBLK")
					(8 . "0")
					(62 . 0)
					(6 . "ByBlock")
					(370 . -2)
			(entmake n)
	(setq
		htx (/ ech 500.0)
	(setq lst_pt
		(l-coor2l-pt
			(vlax-invoke
				hatch
				'IntersectWith
				nw_pl
				acExtendThisEntity
			T
	(foreach el lst_pt
		(cond
				(setq
          ori_txt (* pi 0.5)
				(setq
          ori_txt 0.0
		(cond
					(progn
	(initget 9)
	(entmakex
		(vl-list*
			(cons 0 "INSERT")
			(cons 67 0)
			(cons 410 "Model")
			(cons 8 "GRID")
			(cons 2 "A-NORTE")
			(cons 10 pt_ins)
			(cons 41 ech)
			(cons 42 ech)
			(cons 43 ech)
			(cons 50 0.0)
			(cons 70 0)
			(cons 71 0)
			(cons 44 0.0)
			(cons 45 0.0)
	(vl-list*
		(cons 0 "INSERT")
	(prin1)
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Message 36 of 61
Hannan1
Hi great lisp is it possible to run in all layout tabs without selecting one by one in all tabs if there more layouts it will take more time so is it possible.
Message 37 of 61
barry2104
I am digging up an old thread as I'm looking for a solution for my Situation which is similar to this Topic.
I am in Need of a Lisp which:
  1. generates the Little "+" symbols/lines like shown using the Lisp in Post#2 of this thread. These lines should be inserted into Paperspace rather than Modelspace though
  2. Around/outside the selected viewport, I Need the coordinate value as text (either North- or East coordinate values) displayed North/east Rotation. This should go around all edges of the viewport (typically 4 edges, sometimes more though!). These coordinates should also be inserted to paperspace
  3. The text in the above Point 2) should have a line/polyline aligning to the North/east and sit just under the text, also inserted to paperspace
  4. The length of this line should be 15mm Long, or rather, the viewport should be "Offset" by 15mm and the line should be the required length to go from the viewport-edge to this 15mm Offset line (the Offset line should not be generated/displayed though)
  5. Note: the viewports are not necessarily simple rectangles in shape, and on some plans I may want to have multiple viewports, each showing these coordinates along the edge
Attached is an example of what I'm talking about which is done in this case by Hand.
Has some gifted Lisper out there got time to nut this one out for me?
Running AutoCAD Architecture 2020, in German
Message 38 of 61
barry2104
no one out there with enough smarts to nut out a solution to the request in my post above ^ ?
Message 39 of 61
mihai_bantas
Hy, I attach a code found on the net ... maybe it helps.
A good day...Smiley Happy
Message 40 of 61
I am a beginner in auto cad. please tell me the the command to use this lisp.
@CADaSchtroumpf wrote:
I have making this for meter (initially for French Lambert)
Try it, and adjust it if unit is other.
(vl-load-com)
(if lst
(defun c:ViewPort2Grid ( / js n pt_v l h lst_pt js_obj nw_pl unit_draw AcDoc Space UCS save_ucs WSC nw_style f_pat ob_lst_pt pt_ins format_scale ech hrtx nw_pl_out nw_pl_in hatch_out hatch lst_pt str ori_txt nw_txtpt_ins)
(prin1 "\nSelect a viewport: ")
(while
(null
(setq js
(ssget "_+.:E:S:L"
(list
'(0 . "VIEWPORT")
'(67 . 1)
'(-4 . "!=")
'(69 . 1)
(setq
lst_pt
(list
js_obj (ssadd)
(entmakex
(vl-list*
(cons 67 1)
(cons 70 1)
(setq
Space
save_ucs
(vla-add UCS
"CURRENT_UCS"
(if (not (tblsearch "STYLE" "$GRID"))
(progn
(setq nw_style (vla-add (vla-get-textstyles AcDoc) "$GRID"))
(mapcar
'(lambda (pr val)
(list "SIMPLEX.SHX" 0.0 0.0 1.0 0.0)
(if (not (tblsearch "LAYER" "GRID"))
(vlax-put (vla-add (vla-get-layers AcDoc) "GRID") 'color 7)
(if (not (findfile "QUADISO.pat"))
(progn
(setq f_pat (open (strcat (getvar "ROAMABLEROOTPREFIX") "support\\QUADISO.pat") "w"))
(write-line "*QUADISO,Quadrillage lambert" f_pat)
(write-line "0, -.015,0, 0,1, .03,-.97" f_pat)
(write-line "90, 0,-.015, 0,1, .03,-.97" f_pat)
(close f_pat)
(progn
(close f_pat)
(setq
htx (/ ech 500.0)
(vla-put-layer nw_pl "GRID")
(vla-Offset nw_pl (+ (* htx 2.5) (* htx 10.0)))
(setq nw_pl_in (vlax-ename->vla-object (entlast)))
(setq hatch_out (vla-AddHatch Space acHatchPatternTypeCustomDefined "REPQUADISO" :vlax-True))
(vlax-invoke hatch_out 'AppendOuterLoop (list nw_pl))
(vlax-invoke hatch_out 'AppendInnerLoop (list nw_pl_out))
(vla-put-patternscale hatch_out (/ ech 10.0))
(vla-put-patternangle hatch_out 0.0)
(vla-put-layer hatch_out "GRID")
(vla-evaluate hatch_out)
(setq hatch (vla-AddHatch Space acHatchPatternTypeCustomDefined "QUADISO" :vlax-True))
(vlax-invoke hatch 'AppendOuterLoop (list nw_pl_in))
(vla-put-layer hatch "GRID")
(setq lst_pt
(l-coor2l-pt
(vlax-invoke
hatch_out
'IntersectWith
nw_pl_out
acExtendThisEntity
T
(foreach el lst_pt
(cond
(setq str (strcat " " (rtos (car el) 2 0) " ") ori_txt (* pi 0.5))
(setq str (strcat " " (rtos (cadr el) 2 0) " ") ori_txt 0.0)
(cond
((and el str ori_txt)
(setq nw_txt (vla-AddText Space str (vlax-3d-point el) htx))
(vla-put-layer nw_txt "GRID")
(vla-put-StyleName nw_txt "$GRID")
(vla-put-TextAlignmentPoint nw_txt (vlax-3d-point el))
(if (vlax-invoke nw_pl 'IntersectWith nw_txt acExtendThisEntity)
(vla-put-Alignment nw_txt acAlignmentMiddleRight)
(prin1)
