lisp convert solid volume in liter and gallons
Message 1 of 10
i need a way to convert volume(cube in)  in liter and gallons
i got this to fing the volume,
(defun c:3DVOL (/ eName 3dObj)
(vl-load-com)
(if (and (setq eName (car (entsel "\n >> Select 3D Object for Current Volume: ")))
(= "3DSOLID" (cdr (assoc 0 (entget eName))))
(vlax-property-available-p
(setq 3dObj (vlax-ename->vla-object eName))
'volume))
(princ
(strcat
"\n <!> 3D Volume = "
(rtos (vla-get-volume 3dObj) 2 2)
(princ))
( it's a copy past from another topic i dont have any credit on it lol )
for gallons is x / 231
for liter is  x / 61.02374
thank you
Replies (9)
Message 2 of 10
Kent1Cooper
  (strcat
    "\n<!> 3D Volume = "
    (rtos (vla-get-volume 3dObj) 2 2) " cubic inches, or "
    (rtos (/ (vla-get-volume 3dObj) 231) 2 2) " gallons, or "
    (rtos (/ (vla-get-volume 3dObj) 61.02374) 2 2) " liters. <!>")
  ); strcat
  )); [the others on the end of your current line, completing (princ) and (if) functions
Change those last arguments in the (rtos) functions from 2 to whatever is appropriate to your needs for each type of volume [there's not much point, after all, in dividing the volume by a number to 5 decimal places for liters if you're only going to show the number of liters to 2 decimal places].
Kent Cooper, AIA
Message 3 of 10
here's my new code
(vl-load-com)
'volume))
(princ
(strcat
); strcat
is that normal that in result it's said 2 times ?
exemple:
<!> 3D Volume = 1451526.96 cubic inches, or 6283.67 gallons, or 23786.27 liters. <!>"\n<!> 3D Volume = 1451526.96 cubic inches, or 6283.67 gallons, or 23786.27 liters. <!>"
thank you ?
Message 4 of 10
stevor
Probably is if that string is the last value in that function.
To prevent that, insert:
  ); strcat
) (princ) );
Where it says:
); strcat
S
Message 5 of 10
thank you it works !
Message 6 of 10
Kent1Cooper
To elaborate a little more....
AutoLisp functions always return the result of the last expression in them at the end.  So your (princ (strcat...)) put that text out there, and since that was the last function in the routine, its result was also returned by the overall routine -- that's the reason for the repetition.
The (princ) with no arguments at the end [which you did have in your original code in Post 1] is the typical "quiet exit" that you find in many routines, since it returns nothing, and therefore as the last function in the routine, causes the overall routine to return nothing at the end, leaving the result of the (princ (strcat...)) part within as the last thing put out to the Command: line.  This "exit quietly" function is specifically mentioned in Help for at least one of those printing functions -- (princ) or (print) or (prin1) -- any of which will do the same.
[Personally, I would use the (prompt) function for the reporting part, because that's what it's doing.  The (prin...) functions are built to also have the option to do other things such as send the result out to a file, so while they "work" for the purpose, their capabilities are wasted on mere prompting.]
Kent Cooper, AIA
Message 7 of 10
I replace princ for prompt and it works too,
if i want to save the values as a insert field that ia create for it like US gal for the gallons and LITER
is that possible ?
Message 8 of 10
Kent1Cooper
@Anonymous wrote:
... if i want to save the values as a insert field....
... you will need someone else to help you.  [I haven't had the use of new-enough versions long enough yet to become accustomed to Fields.]
Kent Cooper, AIA
Message 9 of 10
david_wilson8B8GE
Is there a way to be able to select multiple solids in one go without having to union?
Message 10 of 10
Sea-Haven
Another way to display the answer. NOTE 231.0 not 231 to make sure get a real answer not an integer answer.
(alert
(strcat
"\n<!> 3D Volume = \n"
(rtos (vla-get-volume 3dObj) 2 2) " cubic inches, or \n"
(rtos (/ (vla-get-volume 3dObj) 231.0) 2 2) " gallons, or \n"
Just a side note
