Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Lisp automatic dimension
Pls help me Lisp Automatic Dimension
Images depicting what to do
Dim from Red line to Blue line with angle = 90 degrees
Moshe-A
@Anonymous  hi,
can you tell us more what we see here?
is this a manual drawing or do you have some automation?
moshe
ВeekeeCZ
Welcome to these Forums!
I guess you came here to get help on how to code your own programs. Is it that right?
The following code supposed to show you what's possible.  Consider that as a welcome gift because I feel like generous today. Don't hesitate to ask if you have any question about the code.
(vl-load-com)
(defun c:DimToPolyline ( / i p1 p2 px ints obj pl pts ss tmp used pair)
  (if (and (setq ss (ssget '((0 . "LINE"))))
           (setq pl (car (entsel "\nSelect polyline: ")))
           (or (= "LWPOLYLINE" (cdr (assoc 0 (entget pl))))
               (prompt "\nError: Selected object is not a polyline!"))
           (setq obj (vlax-ename->vla-object pl))
           (setq pts (mapcar '(lambda (x) (list (cdr (assoc 10 x))
                                                (cdr (assoc 11 x))))
                             (mapcar 'entget (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))))
    (foreach pair pts
      (foreach i '(0 1)
        (and (setq p1 (nth i pair)
                   p2 (nth (- 1 i) pair))
             (setq tmp (entmakex (list '(0 . "LINE") (cons 10 p1) (cons 11 (polar p1 (+ (angle p1 p2) (/ pi 2)) 1.)))))
             (setq ints (LM:intersections obj (vlax-ename->vla-object tmp) acextendotherentity))
             (setq ints (vl-sort ints (function (lambda (e1 e2)
                                                  (< (distance e1 p1)
                                                     (distance e2 p1))))))
             (setq px (car ints))
             (or (and (LM:UniqueFuzz-p (cons (append p1 px) used) 0.01)
                      (setq used (cons (append p1 px) used))
                      (vl-cmdf "_.dimaligned" "_non" p1 "_non" (car ints) "_non" "@")
                 T)
             (entdel tmp)))))
  (princ)
;; Intersections  -  Lee Mac
;; Returns a list of all points of intersection between two objects
;; for the given intersection mode.
;; ob1,ob2 - [vla] VLA-Objects
;;     mod - [int] acextendoption enum of intersectwith method
(defun LM:intersections ( ob1 ob2 mod / lst rtn )
  (if (and (vlax-method-applicable-p ob1 'intersectwith)
           (vlax-method-applicable-p ob2 'intersectwith)
           (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
    (repeat (/ (length lst) 3)
      (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
            lst (cdddr lst)
  (reverse rtn)
;; Unique-p with Fuzz  -  Lee Mac
;; Returns T if a list contains items considered distinct to
;; a given tolerance
(defun LM:UniqueFuzz-p ( l f )
  (or (null l)
      (and (not (vl-some (function (lambda ( x ) (equal x (car l) f))) (cdr l)))
           (LM:UniqueFuzz-p (cdr l) f)
Hi @Moshe-A,
Thanks for your reply.
Yes, we are developing to automate some continuous repetition work to reduce working time, as well as automate manipulation.
First I draw a Pline, use "test" lisp to create the cells and use "Break" lisp to break the line, then select a red line representing Dim to the blue line.
I did it automatically by lisp (lisp attach)
Hi @ВeekeeCZ
I'm programming code about HTML, SQL. I have no experience with CAD code and CAD commands, I have reviewed the documents in the past 1 month but have no results. I think it is a series of automated CAD commands that are executed. But I still can't find it.
Thank for your gift. This is amazing.
I made drawings with attached lisp.
Regarding your code, I applied it to the drawing, the top part was amazing (image 1), the horizontal part was incorrect (image 2), it was 49
Picture 1Picture 1Picture 2Picture 2
@ВeekeeCZ
Pls help me again
gzeynepberfin
Community Visitor
Community Visitor
Whats the command text in autocad what i have to write that i can work this lisp
