Field Code Formatting Codes
Kyudos
Advisor Advisor
Message 1 of 14
Kyudos
I can't seem to find any comprehensive documentation of AutoCAD field formatting codes - all I seem to be able to discover is what third partties have 'worked out'.
Does anyone have a full specification? It's hard to come up with custom formats otherwise...
Replies (13)
Message 2 of 14
devitg
Maybe it can help. From field and lisp
Message 3 of 14
Kyudos
Sorry for necro'ing this thread but...
I've had cause to look for this again, and still can find anything from AutoDesk 5 years later.
I mean, it seems pretty crucial to the use of field expressions - is there a reason AutoDesk haven't documented it?
Message 4 of 14
hak_vz
Check this link for more detailed fields format explanation.
There is no official documentation about this.
https://blog.bricsys.com/customizing-bricscad-coding-with-field-text-p20/
Miljenko Hatlak
Message 5 of 14
Kyudos
Thanks I did see that page, it's useful, but not complete...e.g.:
"%qf is used by scale factors, but employs values I haven’t figured out yet"
I still don't understand why a years-old feature has zero documentation. How do AutoCAD expect people to use it?
Message 6 of 14
The only real way is do it manually and look at the string produced. Took ages to work out add multiple fields for attribute in block, was very simple in the end.
Message 7 of 14
le-tan-phuc
thank you so much
I was happy to finally find the tutorial through your suggestion
Message 8 of 14
Sea-Haven
This took a while to work out add 2 attribute vales then put answer in a 3rd attribute, could be like att1 = length att2 = height att3 = area a "*" instead of "+".
; add 2 attributes and put the value as a field into the 3rd attribute.
; BY AlanH
(defun c:test ( / obj lst x )
(setq oldatt (getvar 'attdia))
(setvar 'attdia 0)
(command "-insert" "c" (getpoint "\npick point") 1 1 0 (getstring "\nEnter Att1 ") (getstring "\nEnter Att2 ") (getstring "\nEnter Att3 ") "-")
(setq obj (vlax-ename->vla-object (entlast)))
(setq lst '())
(foreach att (vlax-invoke obj 'getattributes)
(princ  "\n")
(setq lst (cons  (strcat "%<\\AcObjProp Object(%<\\_ObjId "
(vlax-invoke-method (vla-get-Utility  (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString att :vlax-false)
">%).Textstring>%"
 ) lst ))
(setq str nil)
(setq x (length lst))
(setq str (strcat "%<\\AcExpr "
(nth (setq  x (- x 1)) lst) " + "
(nth (setq  x (- x 1)) lst) ">%"
(setq x 1 y 4)
(foreach att(vlax-invoke obj 'getattributes)
(if (= x y)
(Vla-put-textstring att str)
(setq x (+ x 1))
(setvar 'attdia oldatt)
(princ)
(c:test)
Message 9 of 14
khix
If you're still looking I made this. It's not everything, but it has most basic rounding and units
Message 10 of 14
Kyudos
Thanks, this is a good resource! But it is just re-emphasizing that AutoCAD still haven't officially, properly, documented this (to my knowledge), now a full DECADE after I first asked about it (and probably a decade before that? maybe more?). I could somewhat understand if field codes were an entirely undocumented feature that users had reverse engineered over a long period. But they are a 'official' feature of the product, with their own interface! AutoDesk are like "Here's a very useful feature. It even has a very flexible, if somewhat complicated, formatting system so you can get things displayed just the way you prefer. Here let me tell you have that all works........ Ha!Ha! JK you're on your own! Good luck!" 🙄
Message 11 of 14
Sea-Haven
Perhaps add the properties available like Area, Length, Radius and so on for objects maybe a table with ticks showing what is available.
You can also do stuff like sum two fields and get a result, 3 Attributes sum 2 and put result in third attribute.
Message 12 of 14
Kyudos
Surely someone at AutoDesk could get Claude to write the docs in next to no time?
Message 13 of 14
Sea-Haven
I am sure need more columns
Message 14 of 14
khix
I posted about this elsewhere and was linked this resource:
https://www.cadforum.cz/en/autocad-field-formatting-codes-full-list-tip15138
