lisp & polyline
lisp & polyline
lisp & polyline
I have no idea how Googl ask why I ask you.
How to catch, in which part of the polylines were 'clicked' when
(entsel "pick element")
Verse in second position gives the coordinates of the point, but its accuracy is probably dependent on the 'pickbox size', so you can not walk to assume that clicked on the polyline.
Jerzy
Already I found the solution
vlax-curve-getClosestPointToProjection
Jerzy
Kent1Cooper
Try putting that (entsel) result into a variable:
(setq esel (entsel "pick element"))
and following that with:
(setq picknear (osnap (cadr esel) "_nearest"))
The 'picknear' variable will then hold a location that is truly on the object.
Kent Cooper, AIA
