Question regarding Quickkeys / Alias in Carlson
lunarfaze
lunarfaze
Hello everyone,
I hope this topic is okay but this group always seems to have the answers.
I started working for a new company and unfortunately they use Carlson embedded 2013 which lacks any alias settings (and so much more).  To gain access to a file, I had to copy of a SURV.PGP file of aliases I have used in the past.  The issue I am coming across is that I cannot change certain ones.  For example, the "C" is set to "CIRCLE" just like AutoCAD.  However, when I change the C to COPY, it does not work.  I can add new ones and they work fine, just not change some predefined ones.  Another example, I added CIR for CIRCLE and it works.
Anyone have suggestions?
Thanks as always.
dennis
My first thought is that there is a lisp routine loading that overrides any PGP setting for the "C".  If the Lisp you are using is open, so that you can open it in either NOTEPAD or the Visual Editor, you could check for "defun C:C" and then if found, make a change there.
lunarfaze
No luck so far.  Thanks for the reply.  I am still looking.
