Help me , I need LISP to make points at end of rectangels
Hi all ,
One of my job responsibilities is to give the building coordinates to the surveyors , So am using Coorn.Lsp
it's very easy and very useful . But every time i have to put the points manually at the corners of the footings ( Rectangles+Poly-lines )
if any one have a LISP to make it automatically i will be thankful for him
Regards all
ВeekeeCZ
Try this one...
;; Alan J. Thompson, 04.15.10
;; Mods by BeekeeCZ, 2017-01-04
(defun c:PolylinePoints (/ ss)
  (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
       ((lambda (i / l lst)
          (while (setq e (ssname ss (setq i (1+ i))))
            (foreach x (entget e)
              (and (eq 10 (car x))
                   (not (member (setq l (list (cadr x) (caddr x) (cdr (assoc 38 (entget e))))) lst))
                   (setq lst (cons l lst))
                   (entmakex (list '(0 . "POINT")
                                   (cons 10 l)))))))
         -1))
  (princ)
Original found HERE
braudpat
Hello from France
Welcome to the Autodesk / AutoCAD Forums !
An other Lisp/VLisp routine "NOD-PL" from Bred (cadxp.com)
which runs on ANY Plines 2D/3D ...
To load the Lisp/VLisp routine:  APPLOAD <Enter>
To run the routine:  NOD-PL <Enter>
And if you need the "same" to mark insertion of Blocks, I have "NOD-INS" !?
Happy New Year and THE HEALTH, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Kent1Cooper
Here is another, which works on 3D and "heavy" 2D Polylines as well as LightWeight ones.
Kent Cooper, AIA
Ha ha ha ha
it's working
appreciate your help
best regards
ahsattarian3
(defun c:plv ()
(setq ss (ssget '((0 . "*polyline"))))
(setq reg (ssadd))
(setq n (sslength ss))
(setq k -1)
(repeat n
(setq k (1+ k))
(setq s (ssname ss k))
(setq cl 1)
(cond ((vlax-curve-isclosed s) (setq cl 0)))
(setq m (+ (fix (vlax-curve-getendparam s)) cl))
(setq i -1)
(repeat m
(setq i (1+ i))
(command "_.point" "_none" (trans (vlax-curve-getpointatparam s i) 0 1))
(ssadd (entlast) reg)
(setq nam (strcat (menucmd "M=$(edtime,$(getvar,date),YYYYMODDHHMMSS)") (itoa (abs (getvar "millisecs")))))
(command "block" nam (getvar "viewctr") reg "" "insert" nam (getvar "viewctr") 1.0 1.0 0.0)
(princ)
