Link Website for F1 Help
Hello everyone
If I move the cursor over a ribbon button, I can call the help for this function / plugin with F1. How can I link a video/website for my own plugin?
So that when I press F1 a web link opens (for example my video blog) for this application.
Or How can I add just a Html File as Help File for my command (F1-Help)
Sea-Haven
Have a look at this, there was some other comments about problems making your own, regarding trying to remove.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Au...
Google "extended help files Autocad"
I've already tried it all. I took exactly this example, created an .xaml file, but instead of the text from the Xaml file, an AutoCAD standard help appears. I've been on it for hours and I'm slowly despairing.
or can maybe send me someone a example .xaml File?
Sea-Haven
I think the problem is the element ID if like me you copy and pasted to make a mnu or cuix, You may be able to edit the cuix find the ID and change it to your ID. Or even make an ID, looking at my custom mnu when loaded as a CUI the items get an ID assigned.
