help fixing my lisp
help fixing my lisp
Message 1 of 10
help fixing my lisp
hi everyone,
I have a lisp for automatic view-ports, that has been created by someone here, however I need a small adjustment for naming the floor. right now when I use it, it reads 21st to 21th same to 22nd to 22th.
from 20th floor, all the floors will read it with th.
could someone please adjust this to be 21st, 22nd, 23rd same with floor 30s,40s,50s and 60s.
thank you in advance,
waseem
Replies (9)
Message 2 of 10
devitg
Please upload the sample.dwg where you have to apply such LISP
Message 3 of 10
Kent1Cooper
Something like this partial adjustment [untested] ?
(repeat (setq FN (length Ycor)) ;; replacing only the original (repeat) function that starts with this
  (setq
    FY (nth (setq FN (1- FN)) Ycor)
    Fname
      (if (= FN FNT)
        "ROOF" ; then
        (strcat ; else -- numbered floors
          (itoa (1+ FN))
          (cond
            ( (and
                (= (rem FN 10) 0); i.e. (1+ FN) ends in 1
                (/= FN 10); not 11th
              ); and
              "st" ;; [change to "ST" if desired]
            ); end-in-1 condition
            ( (and
                (= (rem FN 10) 1); i.e. (1+ FN) ends in 2
                (/= FN 11); not 12th
              ); and
              "nd" ;; [change to "ND" if desired]
            ); end-in-2 condition
            ( (and
                (= (rem FN 10) 2); i.e. (1+ FN) ends in 3
                (/= FN 12); not 13th
              ); and
              "rd" ;; [change to "RD" if desired]
            ); end-in-3 condition
            ("th"); none-of-the-above -- all others [to "TH" if desired]
          ); cond
          " FLOOR"
        ); strcat
      ); if & Fname
    Fname_lst (cons (list FY Fname) Fname_lst))
  ); setq
); repeat
Kent Cooper, AIA
Message 4 of 10
@Kent1Cooperdidn't work, could you please upload into a lisp file so I can test it again
Message 5 of 10
Kent1Cooper
If you simply may not have replaced the right lines, I tried -- lines 50 through 62 in the original are replaced by lines 50 through 84 in the attached.  I did not test it.
Kent Cooper, AIA
Message 6 of 10
@Kent1Cooperstill there's an error when I test it. I might upload the video of my drawings so you can have an idea of how this lisp works. thanks
Message 7 of 10
hak_vz
Try code in attachment.
Miljenko Hatlak
Message 8 of 10
@hak_vzhi, lisp file still not accurate, please see attached Cad file.
once you appload the file, you just need to select the box to create view-ports for you.
however last floor should be roof and that's ok, but if you notice it'll create you 21th floor and 21st floor.
please don't change the way it is, the x and y, I just need an adjustment for the floors so it reads probably.
regards,
Waseem
Message 9 of 10
Kent1Cooper
My error....
This line:
has an extra right parenthesis.  Change that to:
 and try again.
Kent Cooper, AIA
Message 10 of 10
@Kent1Cooperworks perfect, thanks
