linestyle issues
linestyle issues
AHuynhM8MBE
Message 1 of 18
linestyle issues
AHuynhM8MBE
when i convert dgn into a dxf/dwg file and someone else opens the dxf/dwg file why cant they see the linestyle in it while i can?
Replies (17)
Message 2 of 18
paullimapa
has this always been a problem?
have you tried posting in microstation forum?
can you share a sample dgn & dwg file and do a screenshot showing exactly how the linetype should look like?
Paul Li
IT Specialist
@The Office
Message 3 of 18
AHuynhM8MBE
has this always been a problem? Yes
have you tried posting in microstation forum? Not Yet, Hoping it could be resolved here first.
AHuynhM8MBE_1-1750786063032.png how it looks after i exported from dgn to dxf and open it.
 AHuynhM8MBE_0-1750785940160.png how it looks when others open it and when i reopen it later after saving the file.
Message 4 of 18
paullimapa
can you attach sample dgn & dwg?
Paul Li
IT Specialist
@The Office
Message 5 of 18
AHuynhM8MBE
it wont let me add a dgn file. i have added a dxf file though.
Message 6 of 18
paullimapa
when I open your dxf file on my AutoCAD the linetypes show up:
They also show up after saving as dwg
Paul Li
IT Specialist
@The Office
Message 7 of 18
Sea-Haven
You can post a zip file so dgn -> zip
Message 8 of 18
AHuynhM8MBE
i've attached a zip file with the dxf & dgn, i just opened it and the lines aren't showing. -_-
Message 9 of 18
paullimapa
Did you try opening the dwg I attached which was saved from your dxf?
Paul Li
IT Specialist
@The Office
Message 10 of 18
AHuynhM8MBE
for our projects it has to be sent as a dxf file and not dwg.
Message 11 of 18
AHuynhM8MBE
was there are difference in read files between dxf & dwg so that the linestyles show up?
Message 12 of 18
paullimapa
nope...like I posted in my reply, I just opened your dxf in AutoCAD and that already showed the linetypes, then for the sake of argument I saved it as dwg and that still showed the linetypes. The question now is when you open the dwg I saved do you see the linetypes?
Paul Li
IT Specialist
@The Office
Message 13 of 18
AHuynhM8MBE
here's the zip file
Message 14 of 18
paullimapa
When I open your example.dxf in AutoCAD, at first I don't see the linetypes.
Then I zoom in closer to one of the areas and then enter command REGEN I now see the linetypes.
Provide others you've given the dxf to with these same instructions and they also should see the linetypes shown:
Paul Li
IT Specialist
@The Office
Message 15 of 18
AHuynhM8MBE
is there any way to make the file show the lines without having to type in anything when you open it?
Message 16 of 18
paullimapa
sounds like limitation of keeping it as a dxf.
but if saved as dwg then it'll be saved in that zoomed in status showing the linetypes
Paul Li
IT Specialist
@The Office
Message 17 of 18
scot-65
While in AutoCAD:
command VIEWRES
and set to the highest value.
Answer Yes to the fast zoom question.
Command: VIEWRES
Do you want fast zooms? [Yes/No] <Y>: Y
Enter circle zoom percent (1-20000) <20000>:
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 18 of 18
paullimapa
@AHuynhM8MBE and yet another set of helpful instructions for users receiving the dxf but must be executed at least once when the dxf file opens since by default the setting is 100
Paul Li
IT Specialist
@The Office
