modify lisp to link selected blocks with nearest block
jtm2020hyo
jtm2020hyo
First request:
Attached lisp request a select a block to create a link with the nearest point. but all block with the same name is automatically linked to their nearest block
what I request is to modify this attached lisp-routine to work just in selected blocks/dynamic-blocks (no all blocks with the same name)
Second Request:
Attached lisp allow just link with the nearest block with above 180 grades ( since 0 grades to 180 grades relative in each rotation block individually ).
What I need is to convert that 180 grade allowed to 2 variables or 1 range that can be modifiable for the user. (default since 0 grades to 180 grades)
Image explain better how this lisp work actually
jtm2020hyo
@jtm2020hyo wrote:
First request:
Second Request:
here another attached lisp that works exactly like lisp attached and explained above.
dbhunia
Hi
For Red marked line ....try Lisp......
@jtm2020hyo wrote:
First request:
Second Request:
But for second point what should be the reference point for measuring angle........
But show me your workout First .....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
jtm2020hyo
until now, your lisp-routine work perfectly.
thanks for the help.
the first request was solved.
jtm4890
0 sexagesimal degrees as center (for 180° = 90° until -90°)
