laymrg script
laymrg script
mpizzino
Message 1 of 11
laymrg script
mpizzino
Does anyone have an idea how to write a laymrg script with the code on a single line as opposed to several lines?  The problem I'm having is, when the script runs the old layer and the two spaces after it, it thinks the rest of the string is part of the layer name.  Is there any way to force the script to stop reading the layer name after "old layer"?  I've tried everything I can think of to force it to read the layer name correctly, to no avail.  The ultimate goal is to laymrg survey layer from a surveyor to our company standard layers.  I want to copy all the survey layers to excel then set up a second tab that references the survey layer into the script line:
;Survey Layer  Company Layer
-LAYMRG
Nold layer Nnew layerY
Copying the code to notepad gives me this ( _.-LAYMRG N old layer  N new layer Y) but it gets hung after "old layer" because it thinks everything after "old layer" is part of the layer name.
Replies (10)
Message 2 of 11
JTBWorld
Try enclose the layer names within double quotes.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 3 of 11
mpizzino
Unfortunately quotes and double quotes around layer names yield the same hang up after the first layer name:
_.-LAYMRG
N "g-e-minor" N "V-TOPO-MINR" Y
_.-LAYMRG
N ""g-e-minor"" N ""V-TOPO-MINR"" Y
Message 4 of 11
JTBWorld
Here’s something I used long time ago:
(defun layermerge (oldlay newlay)
(if (tblsearch "layer" oldlay)
(progn
(command "._-layer" "_u" oldlay "")
(if (tblsearch "layer" newlay)
(progn
(command "._-layer" "_u" newlay "")
(command "._laymrg" "_n" oldlay "" "_n" newlay)
(if (wcmatch (getvar "cmdnames") "*LAYMRG*")
(command "_yes")
(command "._rename" "_la" oldlay newlay)
Jimmy Bergmark
Message 5 of 11
Kent1Cooper
@mpizzino wrote:
Does anyone have an idea how to write a laymrg script with the code on a single line as opposed to several lines?  ....
Can you process the Excel information in a way that gives you "real" Enters?  I think you need those to complete the Layer names, which in Script format I think means you need to move down to additional lines of code.
Kent Cooper, AIA
Message 6 of 11
mpizzino
I'm exploring the idea of adding carriage return into the blank cells that would other be the space in notepad.  So when its all copied from excel to notepad, it will be a return to the next line instead of a space (which moving one cell left to right is interpreted as a space when pasted into notepad.)
Message 7 of 11
LyleHardin
It's been a while for me, but doesn't a semicolon represent an Enter in scripts?
** EDIT **
@mpizzino  I'm giving this a whirl. Yes, I see what you mean. Interesting. I get the same errors. I have no answer at the moment.
Message 8 of 11
LyleHardin
Here ya go. Try making your spreadsheet export to a script file but make each line a LISP routine like this:
(command "-LAYMRG" "N" "border" "N" "C-RIVR-NEW")
So your excel file will have to have a bunch of columns with double quotes in them.
Message 9 of 11
mpizzino
Thank you for the response!
Replicating your suggestion -  (command "_.-LAYMRG" "N" "g-e-minor"  "N" "V-TOPO-MINR" "Y") is hanging on me after the second layer input.
Message 10 of 11
mpizzino
With a little massaging this does the trick"
(command "_.-LAYMRG" "N" "g-e-minor" "" "N" "V-TOPO-MINR" "Y")
Looks like this in excel:
(command"_.laymrg""N""g-e-major""""N""V-TOPO-MAJR""Y")
Now I can replicate the lines and use cell referencing in the layer cells.  Then copy the rows back to notepad.
Message 11 of 11
Kent1Cooper
In command macros, yes, but not in Scripts.
Kent Cooper, AIA
