;;; CADALYST 07/08 www.cadalyst.com/code
;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES
;;; AND PUTS THEM IN AREARON LAYER
;;; CREATED BY RON MANEJA 31JAN08
;;; USER INPUTS: SCALE, POLYLINE SELECTION
(defun C:AAA(/ allx ally areaobj counter ctr
el entity-name entnamevla mysset
pt tst vertex x y
(vl-load-com)
(COMMAND "_.UNDO" "BE")
(set_var)
(if (= (tblsearch "LAYER" "AREA"))
(command "-LAYER" "M" "AREA" "c" "007" "" "LT" "Continuous" "" "LW" "0.00" "" ""))
; (if
; (tblsearch "Layer" "AREARON")
; (command "._layer" "_thaw" "AREARON" "_on"
; "AREARON" "_unlock" "AREARON" "_set"
; "AREARON" "" ) ;_ closes command
; (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command
(if (null sch)
(setq sch 1.0)
(initget 6)
(setq temp (getreal (strcat "\nENTER SCALE <"
(rtos sch 2 2)
(if temp
(setq sch temp)
(setq temp sch)
(if (null precision)
(setq precision 1)
(initget 6)
(setq prec_temp (getint (strcat "\nHOW MANY DECIMAL PLACES?: <"
(rtos precision 2 2)
(if prec_temp
(setq precision prec_temp)
(setq prec_temp precision)
(prompt "\nSELECT CLOSED POLYLINES:> ")
(setq
mysset (ssget '((0 . "POLYLINE,LWPOLYLINE") (-4 . "&") (70 . 1)))
counter 0
(if mysset
(progn
(while (< counter (sslength mysset))
(setq allx 0
ally 0
ctr 0
tst 1
entity-name (ssname mysset counter)
EL (entget entity-name)
entnamevla (vlax-ename->vla-object entity-name)
areaobj (vla-get-area entnamevla))
(while (assoc 10 el)
(setq vertex (cdr (assoc 10 el))
ctr (+ ctr 1)
x (car vertex)
y (cadr vertex)
allx (+ allx x)
ally (+ ally y)
EL (cdr (member (assoc 10 el) el))))
(setq x (/ allx ctr)
y (/ ally ctr)
pt (list x y))
(command "text" "j" "mc" pt (* sch 2.5) "0" (rtos areaobj 2 precision))
(setq counter (+ counter 1)))
(alert "\nNO CLOSED POLYLINES/LWPOLYLINES IN YOUR SELECTION")
(reset_var)
(princ)
(COMMAND "_.UNDO" "END")
(princ)
(defun set_var ()
(setq oldlayer (getvar "clayer"))
(setq oldsnap (getvar "osmode"))
(setq temperr *error*)
(setq *error* traperror)
(setvar "osmode" 0)
(princ)
(defun traperror (errmsg)
(command nil nil nil)
(if (not (member errmsg '("console break" "Function Cancelled"))
(princ (strcat "\nError: " errmsg))
(setvar "clayer" oldlayer)
(setvar "osmode" oldsnap)
(princ "\nError Resetting Enviroment ")
(setq *error* temperr)
(princ)
(defun reset_var ()
(princ)
ERROR:
ENTER SCALE <50>:
HOW MANY DECIMAL PLACES?: <1>:
Select objects: Specify opposite corner: 2 found
Select objects:
Unknown command "1606". Press F1 for help.
nil
NO SUM AREA
NO INSERT LOCAL AREA
NO SUM TOTAL AREA.
