@sigmmadesigner wrote:
(defun c:LL ()
I fail to see what that has to do with Renaming Layers, but just for your information, it can be much shorter. You can do multiple Layer operations in one Layer command [which will also make it faster, not getting in and out of (command) functions again and again], and you can assign Layer options [such as Color] to more than one Layer at a time with comma-separated Layer names, and you don't have to specify Continuous as a linetype, since that is always the default.
(defun c:LL ()
(command "_.layer"
"_new" "ALVENARIA DE PROJETO,ALVENARIA DE DEMOLIÇÃO,LINHA DE CORTE,NBR,LINHA DE COTA,TRAÇO FINO,DETALHE FINO"
"_new" "DETALHE MÉDIO,TRAÇO MEDIA,TEXTO ARIAL,TEXTO ROMANS,TEXTO TÍTULO,JARDINAGEM,AREA,FORMATO,MOBILIARIO,HIDRO"
"_color" "250" "ALVENARIA DE PROJETO"
"_color" "1" "ALVENARIA DE DEMOLIÇÃO,AREA"
"_color" "3" "ALVENARIA DE REFORMA"
"_color" "4" "LINHA DE CORTE,NBR"
"_color" "252" "LINHA DE COTA,TRAÇO FINO,DETALHE FINO"
"_color" "255" "DETALHE MÉDIO,MOBILIARIO,HIDRO"
"_color" "7" "TRAÇO MEDIA,TEXTO ARIAL,TEXTO ROMANS",TEXTO TÍTULO,FORMATO"
"_color" "79" "JARDINAGEM"
"" ; [end Layer command]
); command
(princ)
); defun
(defun c:CAMADA () (C:LL))
[You can put all the "_new" Layer names into one continuous string -- I just broke it into two groups for website display.]
Kent Cooper, AIA
