environment variable for ACAD directory
Message 1 of 8
Today I've got an easy one. Isn't there an environment variable for the
directory AutoCAD is installed in? I found it with
(vl-registry-read
"HKEY_LOCAL_MACHINE\\SOFTWARE\\Autodesk\\AutoCAD\\R15.0\\ACAD-1:409"
"AcadLocation")
but there's got to be a better way.
Eric S. eschneider@jensenprecast.com
Replies (7)
Message 2 of 8
'Regedit' at the 'run'.(windows)
There's a structure to everything.
Make sure you don't change anything, unless you know what you're doing.
rudy@cadentity.com
Eric Schneider wrote in message
news:9F422EAE260429C73567E05E5484E7A5@in.WebX.SaUCah8kaAW...
> Hello,
> (vl-registry-read
> "AcadLocation")
Message 3 of 8
(findfile "acad.exe") is what I use.
Dan
Message 4 of 8
Or maybe (vl-registry-read (vlax-product-key) "AcadLocation")
Eric Schneider wrote:
> Hello,
> (vl-registry-read
> "AcadLocation")
| Byron Blattel
| CADwerx---Applications for AutoCAD
| byron@cadwerx.net
| http://www.cadwerx.net
Message 5 of 8
Wow! I'd've thought there'd be a (getenv "ACADDIR"){no work} or something
simpler.
I forgot to mention A2ki/W2k.
Thanks guys.
(vl-registry-read (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key))
"AcadLocation")
Message 6 of 8
Here's what I ended up with.
(vla-get-path (vlax-get-acad-object))
Message 7 of 8
hehe...finally! Congratulations...
Silvio
"Eric Schneider" escreveu na mensagem
news:FD3D2B1D4402098C406316B7997C4DC5@in.WebX.SaUCah8kaAW...
Message 8 of 8
Yeah! After weeks of nothing to do (lucky to have a job) but play around
with (vlax-dump-object (vlax-get-acad-object) T), I finally got a simple
solution!
