Layer Properties by Group Filter
christopher.l.evans
christopher.l.evans
I have some layer groups defined in my layer properties manager (PAPER SPACE OFF, PAPER SPACE ON, VIEWPORT OFF, VIEW PORT ON).  I want to turn layers on/off and vpfreeze layers on/off in the vp by the layer group already defined, I'd like the option to run this on the current layout or all layouts.
I spent a day trying to find an example but everything I found ignored the defined layer groups and applied the setting changes to all layers in the drawing.  I found examples on how to create layer groups via lisp but nothing on how to access that list later on.  Is this just something not accessible via lisp?
cadffm
Also if there were, in AutoCAD is no command or function which can handle with layergroups.
Build a function to read which Layers are part of the group (and sub groups?),
so you have a list of layers you can work on.
Sebastian
pendean
Community Legend
Community Legend
ВeekeeCZ
If you are really talking about LAYER GROUP FILTER rather than LAYER PROPERTY FILTER
(vl-load-com)
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/retrieve-layer-names-from-group-layer-filter/m-p/8805768
(defun :grouplayerfilterswlayernames nil
  ((lambda (foo) (foo (entget (cdr (assoc 330 (entget (tblobjname "layer" "0")))))))
    (lambda (enx / dic i itm rtn)
      (and (setq dic (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") enx))))
	   (setq dic (cdr (assoc -1 (dictsearch dic "aclydictionary"))))
	   (while (setq itm (dictnext dic (not itm)))
	     (if (= "AcLyLayerGroup" (cdr (assoc 1 itm)))
	       (setq i	 (assoc 300 itm)
		     rtn (cons (list (cdr i) (mapcar '(lambda (y) (cdr (assoc 2 (entget (cdr y)))))
						     (vl-remove-if '(lambda (x) (/= 330 (car x))) (member i itm))))
			       rtn)))))
      (reverse rtn))))
(defun :layergroupon (name / lst)
  (if (setq lst (cadr (assoc name (:grouplayerfilterswlayernames))))
    (progn
      (command "_.layer")
      (foreach l lst (command "_on" l))
      (command ""))))
(defun :layergroupoff (name / lst)
    (progn
      (command "_.layer")
      (if (vl-position (getvar 'clayer) lst)  ; if current layer is about to off
	(command "_t" "0" "_s" "0" "_u" ""))  ; than make 0 current.
      (foreach l lst (command "_off" l))
      (command ""))))
(defun c:PaperSpaceOn nil  (:layergroupon  "PAPER SPACE") (princ))
(defun c:PaperSpaceOff nil (:layergroupoff "PAPER SPACE") (princ))
christopher.l.evans
@ВeekeeCZ In some cases the list has nil in it one or more times and created chaos when passing the list to a command.  So I added (vl-remove nil lst)
Examples
("group 1" ("a" "b" "c" nil nil nil "d"))
("group 2" ("a" "b" "c" nil "d" "e" "f"))
(defun :vplayergroupoff (name / lst)
    (progn
      (command "_.vplayer")
      (foreach l (vl-remove nil lst) (command "_f" l "_c"))
      (command ""))))
