POLYLINE TO BLOCK
POLYLINE TO BLOCK
pink_floid23
POLYLINE TO BLOCK
pink_floid23
HI
want lisp convert all polylines to block attribute (every one is block ) , convert to same layers  and data , ( pipes 300 in it's layer and 400 in it's layer,,,etc )
ВeekeeCZ
Be so kind and fix your block.
(vl-load-com)
(defun c:Blockade (/ atq s i d l ps ep pt)
  (setq atq (getvar 'attreq)) (setvar 'attreq 0)
  (if (setq s (ssget '((0 . "LWPOLYLINE") (90 . 2))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    d (getpropertyvalue e "Length")
	    l (cdr (assoc 8 (entget e)))
	    ps (vlax-curve-getstartpoint e)
	    pe (vlax-curve-getendpoint e)
	    pt (mapcar '/ (mapcar '+ ps pe) '(2 2)))
      (command "_.-insert" "pipe" "_s" (/ d 59.833333) "_r" (angtos (angle pe ps) (getvar 'aunits) 8) "_non" pt
	       "_.chprop" (setq e (entlast)) "" "_layer" l "")
      (setpropertyvalue e "DIAMETER" "900 mm")
      (setpropertyvalue e "LENGTH" "750 m")
      (setpropertyvalue e "SLOPE" "2.40%%%o")))
  (if s (command "_.erase" s ""))
  (setvar 'attreq atq)
  (princ)
pink_floid23
problem work ,
i need convert polyline to block , and replace the block with the block attribute ,
replace with the same polylines dimension and connected .not separated
pink_floid23
I FIXED THE BLOCK , AND IT WORK , THANKS
BUT ANOTHER THING , WHEN USE LISP T2ATT TO UPDATE VALUE , IT'S NOT IN THE TRUE PLACE TO IT ,, DIAMETER VALUE IN LENGTH AND SLOPE GOSE TO DIAMETER ,,,,
IF SOMETHING WRONG IN ATTRIBUTE SITTING PLEASE TELL ME ,
ВeekeeCZ
Dunno how happened that you have two blocks of the same name but different att order. Probably some routine messes these things up.
Use this mod.
(defun c:T2att (/ s e i c)
  (while (and (princ "\nSelect Text(s)")
	      (setq s (ssget  '((0 . "TEXT"))))
	      (or (setq e (car (entsel "\nSelect Block: ")))
		  (prompt " It's not a block!!")))
      (setq c (cdr (assoc 1 (entget (ssname s (setq i (1- i)))))))
      (cond ((wcmatch c "*mm*") (setpropertyvalue e "DIAMETER" c))
	    ((wcmatch c "*m*") (setpropertyvalue e "LENGTH" c))
	    (T (setpropertyvalue e "SLOPE" c)))))
  (princ)
Anyway, consider this thread over from my side. No more "one more" things.
pink_floid23
THANKS ALOT , LAST THING :
MAKE IT TO ALL IN ONE TIME  , NOT ONE BY ONE
pink_floid23
hi , Mr pbejse , thanks for your help ,
just want one update to the lisp , cause i add new tag to it ,
