Layer names to Excel
Philip-John
Message 1 of 8
Philip-John
I,m new in this Autolisp world. It shall be appreciated if somebody can help me on a project of mine.
I have an AutoCAD project which has more than 140 layers. I'm looking for lisp codes that will collect layer names from selected objects and export to an Excel sheet.
Thanks in advance....
Replies (7)
Message 2 of 8
ВeekeeCZ
Copy-paste selected objects into a new drawing, run Layer properties dialog there and select all the layers, and copy-paste that into excel.
It's a 10-sec job, no need for a lisp.
Message 3 of 8
hak_vz
(defun c:ExpLayToExcel(/ *error* Table _openfile laylist i ss f fname)
	(vl-load-com)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ (strcat "\nError: " msg))
		(if f (close f))
		(princ)
	(defun _openfile (file / sh)
		(setq sh (vlax-get-or-create-object "Shell.Application"))
		(vlax-invoke-method sh 'open (findfile file))
		(vlax-release-object sh)
	(princ "\nSelect objects to extract layer names to Excel >")
	(setq ss (ssget))
	(cond
		((and ss (setq fname (getfiled "Output file:" (getvar "dwgprefix") "csv" 3)))
			(setq f (open fname "w") i -1)
			(while (< (setq i (1+ i))(sslength ss))
				(setq lay (cdr (assoc 8 (entget (ssname ss i)))))
				(if (not (member lay laylist))(setq laylist (cons lay laylist)))
			(foreach layer (vl-sort laylist'<) (write-line layer f))
			(close f)
			(_openfile fname)
	(princ)
Miljenko Hatlak
Message 4 of 8
Philip-John
@hak_vz
Thanks a lot Bro.
Working perfectly..
.... and just a funny (.. or even a serious) request:
Can you make it possible for inverse selection.
I mean, collect non-selected objects layers and export to Excel sheet.
Message 5 of 8
hak_vz
This exports all non-selected layers
(defun c:ExpLayToExcelReversed(/ *error* Table _openfile laylist all_layers i ss f fname)
	(vl-load-com)
		(if f (close f))
		(princ)
	(defun Table (s / d r)
		(while (setq d (tblnext s (null d)))
			(setq r (cons (cdr (assoc 2 d)) r))
	(setq ss (ssget))
	(cond
			(setq all_layers (Table "layer"))
			(foreach layer laylist
				(if (member layer all_layers) (setq all_layers (vl-remove layer all_layers)))
			(foreach layer all_layers
			(close f)
			(_openfile fname)
	(princ)
Miljenko Hatlak
Message 6 of 8
Philip-John
@hak_vz ,
Thanks again.
Perfect..
God bless you..
Message 7 of 8
longnp.water
TỐT
Message 8 of 8
longnp.water
https://forum.dwg.ru/showthread.php?t=81587
Can anyone help me or edit it. Lisp is perfect but can't export the layer to any file. I can't find the .txt .csv file in the selected export folder.
