label slope & distance & edit text of point style lisp
mohamedashraf2014m
Message 1 of 21
mohamedashraf2014m
hello, i want final lisp for making line between two points with slope and distance and arrow and set and edit point text style to the same text height ( set current style ) and select many points to calculate directly plz .
Replies (20)
Message 2 of 21
CLL_PBE
Can you do us, none-civil guys, a favor and post a sample drawing showing the desired results please.,
Message 3 of 21
mohamedashraf2014m
Message 4 of 21
pbejse
Are those "donuts" has the same Z value as the adjacent TEXT string value elevation?
Message 5 of 21
mohamedashraf2014m
yes have same elevation with z value even i use some times points with z value
Message 6 of 21
pbejse
Would it be too much to ask if you can post a drawing file instead of just an image?
You can remove all the sensitive info on it before you post, don't need to be the whole file, only a portion of the layout will be enough.
Message 7 of 21
mohamedashraf2014m
I HAVE ATTACHED CAD FILE
Message 8 of 21
pbejse
One fresh off the grill lisp comin' up...
Stay tuned....
Message 9 of 21
mohamedashraf2014m
WAITING Smiley LOL
Message 10 of 21
mohamedashraf2014m
you forgot me ??
Message 11 of 21
pbejse
@mohamedashraf2014m wrote:
you forgot me ??
Nope, almost there buddy.
Message 12 of 21
pbejse
Conditions:
- Set the TEXTSTYLE :
The program uses the CURRENT TEXTSTYLE font and TEXTSIZE for the label, the arrow size will depend on those values as well.
Procedure:
Select two objects at the time, the program will determine which one is the lower value and for the "arrow" direction
- Suggest to use ByLayer on color
- Suggest to use BLOCK object for the arrow
(defun c:HotOffTheGrill ( / 	Text LWPoly TextData ss data rise run
			 	percentage points ang stringValue linetTo up)
;;;			pBe March 2019		  	;;;
(defun LWPoly (lst cls lay)
  (entmakex (append (list (cons 0 "LWPOLYLINE")
                          (cons 100 "AcDbEntity")
                          (cons 100 "AcDbPolyline")
                          (cons 90 (length lst))
                          (cons 70 cls)(cons 8 lay))
                    (mapcar (function (lambda (p) (cons 10 p))) lst))))
 (setq TextData (mapcar 'getvar '("TEXTSTYLE" "TEXTSIZE")))
  	(prompt "\nSelect Reference objects")
  	(while
          (and
            (setq ss (ssget  '((0 . "POINT,INSERT"))))
            (= (sslength ss) 2)
	(setq data
           (mapcar
             '(lambda (n)
                (list
                  (cdr (assoc 10 (entget (setq e (ssname ss n))))) e ))
             '(0 1)
          (setq data
             (if (minusp (setq rise
                            (apply '- (mapcar 'caddr (mapcar 'car data)))))
               		 (reverse data) data))
            (setq percentage
               (* 100.00
                  (abs rise)
            	  	(setq run
		         	(apply 'distance (setq xy (mapcar '(lambda (p)
		           		(list (car p)(cadr p))) (mapcar 'car data))))))
            (setq linetTo (lwpoly xy 0 "SR_DIM"))
	    (setq points
	            (mapcar '(lambda (d)
	                       (polar (Car xy)(angle (Car xy)(cadr xy)) d ))
	              			(list
						(- (* run 0.5) (setq l (cadr TextData )))
	            				(* run 0.5)
	            				(+ (* run 0.5) l)
            (setq ang (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv linetTo
                                              (vlax-curve-getparamatpoint linetTo (car points)))))
            (lwpoly (cons (caddr points)
		(mapcar '(lambda (s)
                           (polar (car points) ((eval s) ang (/ pi 2.)) (/ l 3.0))) '(+ -)))
			 1 "Slope_Arrow")
		(setq stringValue (list (strcat (rtos percentage 2 2) "%") (rtos run 2 3)))
	  	(setq textRotation (if
				     (setq up (and (> ang (/ pi 2)) (<= ang (* pi 1.5))))  (+ ang pi) ang ))
	(mapcar '(lambda (pt str)
			(entmakex (list (cons 0 "TEXT")
	                  (cons 10  pt) (cons 11  pt)
	                  (cons 50 textRotation)
	                  (cons 40 (Cadr TextData))
	                  (cons 7 (Car TextData))
	                  '(72 . 4)'(73 . 3)(cons 1  str)))
	                           (polar (append (cadr points)(list 0.0)) ((eval s) ang (/ pi 2.)) (* l 1.25))) '(+ -))
          	  (if up stringValue (reverse stringValue))
  (princ)
HTH
Message 13 of 21
mohamedashraf2014m
this is very nice but i want also to put point elevation text perpendicular to the line for each object and also  i want to select multiple objects and make slope for multiple points not only 2 points222222222.PNG
Message 14 of 21
pbejse
Message 15 of 21
mohamedashraf2014m
i want only for now to to put elevation value perpendicular to the line
for multiple selection no need for now
so please help me in making this elevation text
and thank you for your help
Message 16 of 21
mohamedashraf2014m
any body can help me in putting z value ( elevation ) perpendicular to line for every point like this
according to this lisp routine ?????
Message 17 of 21
pbejse
If you ask nicely I'll do it.
Message 18 of 21
mohamedashraf2014m
please can you make for me
Message 19 of 21
pbejse
Sure buddy
As before:
Conditions:
the arrow size will depend on those values as well. Procedure: Select TWO (2) objects at a time, the program will determine which one is the lower value and for the "arrow" direction
Selecting all objects at one go is impractical as the program will most likely mess up the pairing.
Not that it's impossible to come up with a program that works all the time ( debatable ) but I personally wouldn't spend time writing one.
See attached file.  hOToFFtHEgRILL.LSP (quick mod of the previous routine)
command:  hOToFFtHEgRILL
Select objects: Specify opposite corner: 2 found
HTH
Message 20 of 21
Nurlan_Ahmadov2
Community Visitor
Community Visitor
Good day Mr. PBEJSE,
I used the LISP, this is very good job thank you for this.
Could you please make a few changes?
