Text issues with lsp after cleaning files
crapai
crapai
We're having issues with our text on some cad files that we use to import into Revit. These cad files were giving us errors. The Autodesk Expert Elite expert network member suggested that I start by cleaning up the cad files. I did purges and audits. In addition I also did a purge of all the regapps. Now when files are open, on multiple computers, we are noticing that the text looks correct for a half second and then switches to another type. We are running a lsp that is intended to change the text over to arial so that it displays correctly in Revit. Below is an example of it in detail title blocks. In these example the text looks like the correct location at first but the text does not look like arial. This is also happening with normal text except the text does start by looking like arial. I've posted this before here.Correct text location but not arialCorrect text location but not arialbroken textbroken textcommand line on openingcommand line on opening
pendean
Community Legend
Community Legend
See your other post on the same identical topic... .
