Problems running fndshape.lsp - gives me "too many arguments" error
Haider_of_Sweden
Haider_of_Sweden
Please have a look at this lisp-script - it used to work and now it doesn't anymore. Not sure what happened between then and now. I am using AutoCAD 2016.
It's a life saver for me, to fix this irritating popup that tells me a SHX is missing. This lisp tells me where this shape-file is being used.
;; FNDSHAPE.LSP  Copyright 2006  R.K. McSwain  all rights reserved
;;  Author: R.K. McSwain
;;  Initial Release [27 FEB 2005]
;;  Feel free to copy, and modify as desired, just
;;  retain this header and append as necessary.
(defun c:fndshape
		  (/	  ENT
		   LT	  OUTPUT
		   SHPNST ST
		   FN	  FP
		   I	  INS
		   ITEM	  LTENT
		   LTNAME LTOBJ
		   OBJ	  OSTR
		   REF	  SHAPENM
		   SHAPENO
		   SHPN	  STENT
		   STNAME STOBJ
		   TMP
  (vl-load-com)
  (setq output '())
    ; Step 1 - Find complex linetypes that reference a SHAPE
  (while (setq lt (tblnext "ltype" (not lt)))
    (setq ltname (cdr (assoc 2 lt)))
    (setq ltObj (tblobjname "ltype" ltname))
    (setq ltEnt (entget ltObj))
    (setq i 0)
    (while (< i (length ltEnt))
      (setq item (nth i ltEnt))
      (if (and
	    (eq (car item) 74)
	    (eq (cdr item) 4)
	(progn
	  (setq shapeno (itoa (cdr (nth (1+ i) ltEnt))))
	  (setq
	    shapenm (cdr (assoc 3 (entget (cdr (nth (+ i 2) ltEnt)))))
	  (setq	ostr
		 (strcat "LINETYPE ["	  ltname
			 "] uses SHAPE # ["
			 shapeno	  "] in the file ["
			 shapenm	  "]"
	  (setq	output (cons ostr output)
		i      10000
      (setq i (1+ i))
    ; Step 2 - Find loaded SHAPE FILES
  (while (setq st (tblnext "style" (not st)))
    (setq stname (cdr (assoc 2 st)))
    (setq stObj (tblobjname "style" stname))
    (setq stEnt (entget stObj))
    (if	(eq 1 (logand (cdr (assoc 70 stEnt)) 1))
      (setq ostr
		   (strcat "The following SHAPE FILE is loaded: ["
			   (vl-princ-to-string (cdr (assoc 3 st)))
    (setq i (1+ i))
    ; Step 3 - Find inserted SHAPES
  (setq tmp (ssget "X" '((0 . "SHAPE"))))
  (if tmp
    (progn
      (setq i 0)
      (while (< i (sslength tmp))
	(setq obj (ssname tmp i))
	(setq ent (entget obj))
	(setq shpn (cdr (assoc 2 ent)))
	(if (not shpn)
	  (setq shpnST "An unknown shape ")
	  (setq shpnST (strcat "SHAPE named " shpn "] "))
	(setq ins (cdr (assoc 10 ent)))
	(setq ref (cdr (assoc 2 (entget (cdr (assoc 330 ent))))))
	(setq ostr (strcat shpnST
			   "is INSERTED in "
			   ref
			   " at "
			   (vl-princ-to-string ins)
	(setq output (cons ostr output))
	(setq i (1+ i))
  (if output
    (progn
      (setq output (reverse output))
      (setq fn (strcat (getenv "temp") "\\fndshape.txt"))
      (setq fp (open fn "w"))
      (foreach item output
	(write-line item fp)
      (close fp)
      (startapp "notepad" fn)
    (alert "Nothing found")
  (princ)
(princ "\n Type FNDSHAPE to run...")
(princ)
dlanorh
This won't be much help, but this runs error free in 2012. I can't test it in anything higher, but perhaps someone else can.
I am not one of the robots you're looking for
ВeekeeCZ
@Haider_of_Sweden , try to locate the line which fails first. Look HERE how to do that.
Then, perhaps, the author itself could help. @rkmcswain
Haider_of_Sweden
None of the methods helped. So I looked into the APPLOAD and erased everything I had put there that got loeaded during startup.
What I discovered was that this code was the cause FNDSHAPE stopped working:
;;Close all drawing without saving
;;Original code by someone on Autodesk forums
;;Modified by cadmoogle to 'Close last drawing'
(defun doc:CloseAllButActive (TrueOrFalse / cnt)
(setq cnt 0)
(vlax-for Item (vla-get-Documents (vlax-get-acad-object))
(if (= (vla-get-Active Item) :vlax-False)
(progn
(vla-close Item TrueOrFalse)
(setq cnt (1+ cnt))
cnt
); end defun
(defun close (/) ;added by cadmoogle to close the last drawing without saving
(command "close" "Y")
(princ)
); end defun
(defun c:CCC ( / cnt) ;Closes all drawings except active
(setq cnt (doc:CloseAllButActive :vlax-False))
(if (> cnt 0)
(princ (strcat "\n(" (itoa cnt) ") document" (if (> cnt 1) "s" "") "closed without saving."))
(princ "\nNo other documents to close.")
(close)
(princ)
); end defun
please note the bold part. When I commented it, things started to work again.
What could be the reason?
DannyNL
You cannot defun a close command as this is a protected LISP command.
So the function close has to be renamed to something different, i.e. closedwg.
