Join command in Advance Steel
Hollygibbs96
Message 1 of 8
Hollygibbs96
Hi All. I'm after some help with this pleasae.
I want to insert 4 blocks into my drawing to form a square shape. The original 4 entities  that I made are polylines and are saved as blocks in one drawing called BLOCKS_1.
I start a new drawing and insert  BLOCKS_1 into my drawing. This then makes the 4 polyline blocks available in my current drawing.
I am then inserting the 4 blocks each at their relative 0,0,0 point which arranges the blocks how I want them.
Heres where I cant get the join command to work. (I can manually join the 4 entities together using the JOIN command)
After inserting the 4 blocks I am exploding them so they are now polylines and their end points are touching to form a square.
this is an example of the code to only insert and explode 1 of the entities. I repeat this insert 3 more times, and change the ENTLAST to Ent2 Ent3 Ent4
(command "-insert" "Infil_HL" (0.0 0.0 0.0) "" "" "") ;Infil_HL is the block name one of the 4 entities thast are present in the drawing
(setq Ent1 (entlast))
(command "_explode" Ent1)
now when I run the join command it won't join the 4 entities into one.
(command "_join" Ent1 Ent2 Ent3 Ent4)
Regards Tony
Replies (7)
Message 2 of 8
komondormrex
i think there should be pedit command instead. maybe like the following.
(command "-insert" "*Infil_Hl" "0,0,0" "1" "")   ; inserts and explodes altogether
(setq Ent1 (entlast))         ; considering the only entity in a block is pline
;repeat 3 times more
(command "_pedit" "_m" ent1 ent2 ent3 ent4 "" "_j" "" "")
Message 3 of 8
ВeekeeCZ
I would use a "previous" selection for JOIN command.
(command "_-insert" "Infil_HL" "_s" 1 "_r" 0 "_non" '(0. 0.))  ;Infil_HL is the block name one of the 4 entities thast are present in the drawing
(command "_explode" "_last")
(initcommandversion)
(command "_.join" "_p" "")
Message 4 of 8
Moshe-A
@Hollygibbs96  hi,
There is no problem with calling JOIN from (command) function.
your command is missing a closing enter. make sure your geometric
has no hidden gaps.
(command "._join" ent1 ent2 ent3 ent4 "")
Moshe
Message 5 of 8
Sea-Haven
Have a look at your other post, suggestions there.
https://www.cadtutor.net/forum/topic/98697-autocad-join-command/
Message 6 of 8
Hollygibbs96
Hi. thanks for the ideas. I have used your idea with the PEDIT approach and it has almost worked. It joins 3 of the entities but not the 4th. The program runs right through.
Any ideas why the 4th entity wont join??
Ive included my DWG file for you to have a look and also my lisp routine. The bulk of the routine works well its just the join command
Regards
tony
Message 7 of 8
komondormrex
hey,
that's because the last entity getting after block Infil_HR is exploded is NOT a pline, but a hole. make the pline LAST in this block, eg. by cut&paste and it will work just fine!-) and do not forget to switch the osnap off when the lisp is running (may be done with (savevartoold) yet) .
Message 8 of 8
devitg
Just so
(command "._PEDIT" topline "_J" "all" "" "" )  ;topline infilHL bottomline infilHR "" "_j" "" "")
