Issue with Lisp to record values without tolerances in a table, Autocad LT
- Mute
- Permalink
- Report
Hi everyone,
I’m working with a Lisp file that I need to use in AutoCAD LT, which, as we know, has limited support for Lisp routines. The Lisp creates a table with the dimensions of multiple rectangles. Currently, it records the dimension values but includes tolerances (decimals). I need the values to be recorded without tolerances (whole numbers), even when the values have decimals. I'll post this image to highlight those errors that should not occur:
It also doesn't count always all the rectangles, and I don't know why.
This LISP has to be reliable.
Since this Lisp needs to function in AutoCAD LT, I’m looking for help in making the necessary adjustments so that the table records the rectangles dimensions without decimals. Any guidance on how to achieve this within LT's limitations would be greatly appreciated!
Thank you in advance!
(defun rectangle_dims (e / l a b)
(setq l (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) e)))
(if
(and
(or
(= 1 (logand (cdr (assoc 70 e)) 1))
(equal (car l) (last l) 1e-8)
(equal (distance (car l) (caddr l)) (distance (cadr l) (cadddr l)) 1e-8)
(equal (mapcar '- (cadr l) (car l)) (mapcar '- (caddr l) (cadddr l)) 1e-8)
(equal (mapcar '- (caddr l) (cadr l)) (mapcar '- (cadddr l) (car l)) 1e-8)
(vl-sort (list (fix (distance (car l) (cadr l))) (fix (distance (cadr l) (caddr l)))) '<)
(defun C:TAB (/ *error* ss e old r p1 c)
(vl-load-com)
(setq acObj (vlax-get-acad-object)
acDoc (vla-get-activedocument acObj)
space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
(vla-startundomark acDoc)
;;;;;; Error function ;;;;;;;;;
(defun *error* (msg)
(and
msg
(not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*"))
(princ (strcat "\nError: " msg))
(vla-endundomark acDoc)
(princ)
(if
(setq ss (ssget '((0 . "LWPOLYLINE") (-4 . "<OR") (90 . 4) (90 . 5) (-4 . "OR>"))))
(progn
(repeat (setq i (sslength ss))
(setq e (ssname ss (setq i (1- i)))
c (cond
((cdr (assoc 62 (entget e))))
((cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 (entget e)))))))
c (if (zerop c) 7 c)
(if
(and
(setq dims (rectangle_dims (entget e)))
(setq dims (cons c dims))
(if
(setq old (vl-some '(lambda (d) (if (equal (cdr d) dims 1e-8) d)) r))
(setq r (subst (cons (1+ (car old)) dims) old r))
(setq r (cons (cons 1 dims) r))
(if
(and r (setq p1 (getpoint "\nSpecify table insert point: ")))
(insert_table
(vl-sort
(vl-sort
(vl-sort
(mapcar '(lambda (a) (list (fix (cadr a)) (fix (caddr a)) (fix (cadddr a)) (car a))) r)
'(lambda (a b) (< (cadr a) (cadr b)))
'(lambda (a b) (< (car a) (car b)))
'(lambda (a b) (> (caddr a) (caddr b)))
p1
(princ)
;;The textheight in table depends on cannonscale
(defun insert_table (lst pct / tab row col ht i n acol)
(setq ht (/ 2.5 (getvar 'cannoscalevalue))
pct (trans pct 1 0)
n (trans '(1 0 0) 1 0 T)
tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ 3 (length lst)) 3 (* 1.5 ht) ht))
acol (vla-getcellcontentcolor tab 0 0)
(vlax-put tab 'direction n)
(vla-mergecells tab 1 1 0 2)
(mapcar
(function
(lambda (rowType)
(vla-SetTextStyle tab rowType (getvar 'textstyle))
(vla-SetTextHeight tab rowType ht)
'(2 4 1)
(vla-put-HorzCellMargin tab (* 0.14 ht))
(vla-put-VertCellMargin tab (* 0.14 ht))
(setq lst (cons '(nil "sec" "Lenght" "pcs") lst))
(setq lst (mapcar '(lambda (el) (list (car el) (last el) (cadr el) (caddr el))) lst))
(setq lst (cons '(nil "sp:" nil nil) lst))
(setq i 0)
(foreach col (apply 'mapcar (cons 'list (mapcar 'cdr lst)))
(vla-SetColumnWidth tab i
(apply
'max
(mapcar
'(lambda (x)
((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.0 ht)))
(textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht)))
col
(setq i (1+ i))
(setq lst (cons '(nil "Title") lst))
(setq row 0)
(foreach r lst
(setq col 0)
(vla-SetRowHeight tab row (* 1.5 ht))
(foreach c (cdr r)
(vla-SetText tab row col (vl-princ-to-string c))
(if
(car r)
(progn
(if (/= (vla-get-colorindex acol) (car r)) (vla-put-colorindex acol (car r)))
(vla-SetCellContentColor tab row col acol)
(setq col (1+ col))
(setq row (1+ row))
(princ "\nType TAB to start the command")
