TBLK Command not working
Grainne_Mulcahy3APDT
Community Visitor
Community Visitor
The TBLK command is not working. I have uploaded a TBLK routine to the "APPLOAD" as a lsp file but when I type in the  TBLK command no prompt appears
Any help appreciated
cadffm
ask the programmer! You didn't share the tool/code/program, and your .dwg
so nobody knows what should happen or not,
because it isn't part of standard autocad  - what we known well.
For example: If this tool expect a blockreference on layer "NA1" of a block with name pattern *vi02*
and your dwg doesn't contain such an object, nothing will happen.
Sebastian
pendean
Community Legend
Community Legend
Share that "TBLK routine" here if you want assistance with it, that is unique to you alone at the moment.
Kent1Cooper
@Grainne_Mulcahy3APDT wrote:
.... when I type in the  TBLK command no prompt appears ....
In addition to providing the routine as already requested, answer the most obvious question:  What happens that's different from the prompt you expect?  Nothing at all, perhaps?  Are there any messages?  Etc., etc.
Kent Cooper, AIA
