is there any method to emulate parametric constraint functions, equations or formulas with any value in AutoCAD?
jtm2020hyo
jtm2020hyo
when you create any dynamic block you can add a constraint and edit their values, is possible to link between values for emulate constraints?
...for example, link a text to the elevation of a polyline, or link a block attribute value to one line length.
devitg
@jtm2020hyo , Some like  FIELD ?
jtm2020hyo
50% yes, I want something like fields when working with text, I am searching link properties valies with anything, I mean for example, if field can extract the line length, at the same way I want to edit the text and that the line length change, no sure if possible, this is similar to when constraints edit any length editing dimension.
... another example, is, I want to link the poyline elevation of polyline to 3D cube size in the properties panel, I mean If I edit the elevation then the 3D cube size be edited automatically.
