Lisp for Coincident Constraint
jtm2020hyo
jtm2020hyo
is there any lisp to join multiple objects using the "Coincident Constraint" in the selected points? I mean selected points using "Crossing Selection", for example, similar to Crossing Selection for Stretch Command to just select the points to stretch.
ВeekeeCZ
I do remember this thread of yours.
I was investigating a bit how this could be automated lately... see THIS  routine.
If your issue is still on, post a dwg with states before and after to take a look at what you're trying to do.
jtm2020hyo
attached a file sample, I tried to use _AutoConstrain command but just work with lines, but When I use manually constrain command with perfectly with Wall Objects.
o6ag5Hf
prMQJu2
ВeekeeCZ
@jtm2020hyo
Well, I just wanted to confirm to you that some things with CONSTRAINS might be possible in LISP.
Also, I don't have Architecture so I wouldn't know what's possible with these objects in Acad itself.
It's up to you to explore things! Good luck!
