There is something wrong with my lisp?
Message 1 of 12
(defun C:TH ()
(setvar "cmdecho" 0)
(setq osv (getvar "osmode"))
(setvar "osmode" 0)
(setq A (getpoint "\n Specify first corner of rectangle: "))
(initget (+ 1 2 4))
(setq B (getreal "\n Specify length: "))
(initget (+ 1 2 4))
(setq C (getreal "\n Specify width: "))
(initget (+ 1 2 4))
(setq L1 (getreal "\n Offset from the left side: "))
(initget (+ 1 4))
(setq L2 (getreal "\n Offset from first circle: "))
(initget (+ 1 2 4))
(initget 0 "Point")
(setq F (getreal "\n Specify diameter or [Point]: "))
(setq A2 (polar A 0 B))
(setq A3 (polar A2 (/ pi 2) C))
(setq A4 (polar A (/ pi 2) C))
(setq A5 (polar A 0 L1))
(setq C1 (polar A5 (/ pi 2) (/ C 2)))
(setq C2 (polar C1 0 L2))
(command ".pline" A A2 A3 A4 "close")
(setvar "regenmode" 1)
(cond
  ((= (strcase F) "P") (command ".point" C1 "" ".point" C2 ""))
  ((\= (strcase F) "P") (command ".circle" C1 "_d" F "" ".circle" C2 "_d" F ""))
(setvar "osmode" osv)
(setvar "cmdecho" 1)
There is something wrong with my lisp? I try I draw a rectange with 2 holes, Instead of holes I choose Point for it!
Replies (11)
Message 2 of 12
ВeekeeCZ
@Anonymous wrote:
(defun C:TH ()
(setvar "osmode" 0)
(initget (+ 1 2 4))
(initget (+ 1 2 4))
(initget (+ 1 2 4))
(initget (+ 1 4))
(initget (+ 1 2 4))
(initget 0 "Point")
(cond
Getreal never returns just "P".
Message 3 of 12
hak_vz
@Anonymous
((= (strcase F) "P") .... F is real so strcase will not work
((\= (strcase F) ....it is /=
Use getkword after initget
Miljenko Hatlak
Message 4 of 12
ВeekeeCZ
There are many more flaws. Compare both versions to see the difference.
(defun C:TH ()
(initget (+ 1 2 4))
(initget (+ 1 2 4))
(initget (+ 1 2 4))
(initget (+ 1 4))
;(initget (+ 1 2 4))
(initget 0 "Point")
(setvar "osmode" 0)
  (if (= F "Point")
    (command ".point" C1 ".point" C2 )
    (command ".circle" C1 "_d" F ".circle" C2 "_d" F)
Message 5 of 12
pbejse
(initget 0 "Point")
There are 4 possible outcome from this statement
1. the user enter "p" or "P" : result is "Point"
2. The user enter a real number or integer : 50 or 50.00 will give you a real number
3. The user press enter : result is nil
4. The user press escape : result is "error: Function cancelled"
(cond
  • (Strcase F) will fail if the value is not a string
  • (= f "P") even if you take out strcase and the value is a valid string and not a real number the statement will always be false as typing "P" or "p" will give you give you "Point" and not "P
Say the user did enter  a real/int for diameter, Your code did not acount if the user for that result
To prevent the user from pressing enter, a negative value or 0 use initget 7
Hope this makes sense
Message 6 of 12
Kent1Cooper
There's a 5th possible outcome:
5.  The User types any non-numerical entry other than P or p [or one of those plus more of the word]: the result is that it will scold them and ask again.
And a real/integer entry for the diameter is  accounted for, in the second condition [to draw the Circles], though the test argument for it is not correct.
Kent Cooper, AIA
Message 7 of 12
pbejse
--- Your code did not acount if the user for that result ---
(strcase f) will always produce an error for real/integer input. My point is regardless, what the input,  the cond will not work.
Message 8 of 12
Kent1Cooper
My point was that, although it is not accounted for in a workable  way [because the test argument is not correct], it is accounted for [i.e. they did  include something for the routine to do with a numerical User input].  They just need to fix the test argument to get that condition to function.
Kent Cooper, AIA
Message 9 of 12
Thank you for yourhelping! It works for me!
Message 10 of 12
pbejse
Oh I see now, yes indeed. It must be the second bottle of whiskey that threw me off. 🙂
Message 11 of 12
I want to change 2 holes or 2 points in to layer name is "33" after command is finished, how can I do? I am a new autolisper, So......
Message 12 of 12
pbejse
(defun C:TH ( / _Createthis ipoints)
(defun _Createthis (n l r lst)
    (foreach pt	lst
      (setq ent (list (cons 0 n) (cons 8 l) (cons 10 pt)))
      (entmake (if r
		 (append ent (list (cons 40 r)))
		 ent
(setq lname "33");<----- Your layer name or you can change this to prompt for layer name
(initget (+ 1 2 4))
(initget (+ 1 2 4))
(initget (+ 1 2 4))
(initget (+ 1 4))
(initget 0 "Point")
(setq ipoints (list c1 c2))
(setvar "osmode" 0)
  (if (= F "Point")
    (_Createthis "POINT" lname nil ipoints)
    (_Createthis "CIRCLE" lname f ipoints)
HTH
