Is there a way to reset (initialize - clear) the undo queue using autolisp?
GeryKnee
Message 1 of 10
GeryKnee
Hello everybody
The goal is to ignore (_u :: "nothing to audo")  any changes to the drawing up to the present moment.
Replies (9)
Message 2 of 10
Sea-Haven
If you look into the help there are many settings for undo, one is using lisp is UNDOMARK.
(vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
(vla-endundomark adoc)
If you do undo it will go back to the mark point.
AutoCAD 2024 Help | UNDO (Command) | Autodesk
Message 3 of 10
GeryKnee
(defun c:ClearUndoQueue nil
(princ)
Command:
Command:
Command: _pline
Specify start point:
Current line-width is 0.000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Command:
Command:
Command: _circle Specify center point for circle or [3P/2P/Ttr (tan tan
radius)]:
Specify radius of circle or [Diameter]:
Command: ClearUndoQueue
Command:
Command: _u GROUP
Command: _u Circle GROUP
Command: _u Polyline GROUP
Command: _u PROPERTIES
instead of this , i want to see:
Command:
Command:
Command: _pline
Command:
Command:
radius)]:
Command:
Command: _u Nothing to undo
Message 4 of 10
Sea-Haven
The defun you made just starts and stops the undo, you need to take each line seperately put startmark at start of code and endmark at end of code.
Not sure if that is what you want.
Message 5 of 10
GeryKnee
I see than cannot forget the undo history ( cannot protect a drawing created untill a moment the user wants to stop going back)
Message 6 of 10
Moshe-A
@GeryKnee  hi,
yes you can 😀
explore UNDO command options
undo control none
Moshe
Message 7 of 10
Kent1Cooper
This is what I use:
;; DumpUndoHistory.lsp
(defun C:DUH ()
  (setvar 'cmdecho 0)
  (command "_.undo" "_control" "_none" "_.undo" "")
  (setvar 'cmdecho 1)
  (prompt "\nDumped Undo History.")
  (princ)
Kent Cooper, AIA
Message 8 of 10
GeryKnee
Thank you Sir
Message 9 of 10
john.uhden
@GeryKnee ,
I doubt that there is any way to do that programmatically, but you could SAVE or SAVEAS the drawing and then reopen it.
John F. Uhden
Message 10 of 10
GeryKnee
Dear John, hello.
Thank you for your time and interest.
But as you see , I have informed the forun , the solution has been provided by kent1Kooper.
The function works.
Sincearly,
Gery
