Place Block on Polyline (slide and flip functions)
brendon_butler2
brendon_butler2
I’m requiring a Lisp routine that places a particular block (attached) along a selected Polyline and will be able to slide the block along the Polyline and place it randomly where I need it and depending on which side of the polyline I’m hovering over, the block will flip to one side or the other.
See simple diagram to better illustrate.
DWG with block named “Wall Symbol” attached
Thanks in advance!
Moshe-A
@brendon_butler2 hi,
This one can be solve without lisp 😀
Attached your block, made it dynamic with 2 properties:
1. alignment grip: after you insert the block pick it than pick the alignment grip and drag it hover a pline and it will align right away.
2. flip grip: if after you drag the block it align not on the right side, click the flip and it will switch sides.
enjoy
Moshe
Sea-Haven
Just a comment there is lots of INSULATION lisps out there so pick 2 points and the XXXX will be drawn but can be more or less than 4 X's. It can be made to go above, along or below.
brendon_butler2
Thank you, Moshe. I must admit to never using dynamic Blocks at all.
I've had a quick play already and I see now the possibilities.
Thanks again!
