Is there a lisp file to calculate area & place text at ~center of polyline?
Message 1 of 50
I'm looking for a lisp routine or command that will calculate area of a closed polyline and place text with the area value at the center of the polyline.  I need to do a lot of area calcs for a lot of small rooms?
Any thoughts are appreciated!
Thank you
Brian
Replies (49)
Message 41 of 50
Kent1Cooper
You're right -- I was thinking only LWPolylines, not the "heavy" ones.  But the possibility of the 128 bit applies to either variety.
Kent Cooper, AIA
Message 42 of 50
dduroux1
Awesome! This worked, thanks so much for the assistance
Message 43 of 50
mar_fxp
Good day, excuse me, how can you make this PLAREA list not only select an object, but also add the option to select an object or several objects at the same time, with that you can put the area in several lots with a single selection. I await your response on how to do it. thank you so much
Message 44 of 50
mar_fxp
Buen dia disculpe como se puede hacer esta lista PLAREA no solo seleccionar un objeto sino agregar la opcion de seleccionar un objeto o varios objetos a la vez, con eso se puede poner el area en varios lotes con una sola seleccion . Espero tu respuesta de como hacerlo. muchas gracias
Message 45 of 50
lpradobr
Hi
Your lisp routine works perfectly and saves a lot of work.
Thanks for sharing.
Message 46 of 50
mikeshick
@JTBWorld Super awesome.  I’ve needed your AreaText.lsp  for years.
Curious,
  1. could this be modified to product MTEXT instead of Text?
  2. Automatically include a background mask
  3. Use Current Text Style and the style size
  4. Add multiple area objects
And, could this modified routine also be transformed to do the same thing with the total length of selection of multiple lines, polylines, arcs, and/or splines (minimal requirement of multiple polylines)?
Thank you!
Mike Shick
www.medesigns.us
Message 47 of 50
JTBWorld
@mikeshick Yes it could be done but it might be for a fee.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 48 of 50
danelharut
Привет, я прочитал ваши сообщения о том, как изменить скрипт, но у меня возникли проблемы,Как сделать чтобы в таком видеshinn1-Модель.jpg
Message 49 of 50
danelharut
Привет, я прочитал о том, как изменить скрипт сообщения, но у меня возникли проблемы,shinn1-Модель.jpg
Message 50 of 50
JTBWorld
Is the 4, the number of sides of the area?
It can be done but I don't have time to do it for free right now. If interested to pay for it contact me directly.
Jimmy Bergmark
