- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello experts!
I found this lisp by Tharwat, that counts intersections between two points and it creates a table from the layer info.
I need help to change it so instead of choosing two points I can select the line/pline and get all the intersections in one table for the whole length of the line. Also, if possible, ad at what length along the line/pline the intersection occurs. Would this be possible?
Here’s the code:
(defun c:Test (/ entities i number integer layers lst object point1 p
height point2 result selectionset selectionsetname
singlelayer model table r c inc
(vl-load-com)
(if (and (setq point1 (getpoint "\n Specify first point :"))
(setq point2 (getpoint point1 "\n Specify Second point :"))
(setq selectionset
(ssget "_F"
(list point1 point2)
'((0 . "LINE,*POLYLINE"))
(setq p (getpoint "\n Table insertion point :"))
(progn
(setq height (if (zerop (cdr (assoc 40
(setq st
(entget
(tblobjname "STYLE" (getvar 'textstyle))
(cdr (assoc 42 st))
(cdr (assoc 40 st))
(repeat (setq integer (sslength selectionset))
(setq entities (cons (setq selectionsetname
(ssname
selectionset
(setq integer (1- integer))
entities
(if (not (member (setq singlelayer
(cdr (assoc 8 (entget selectionsetname)))
layers
(setq layers (cons singlelayer layers))
(setq i 0)
(foreach layer layers
(repeat (setq number (length entities))
(if
(eq
(cdr
(assoc 8
(entget (nth (setq number (1- number)) entities))
layer
(setq lst (cons layer (setq i (1+ i))))
(setq result (cons lst result))
(setq i 0)
(setq model (vla-get-modelspace
(vla-get-activedocument (vlax-get-acad-object))
(setq table (vla-addtable
model
(vlax-3d-point p)
(1+ (length result))
2
(* height 2.)
(* height 10.)
(vla-settext table 0 0 "Section A - B")
(setq r 0
c 0
inc -1
(repeat (length result)
(vla-settext
table
(setq r (1+ r))
c
(car (nth (setq inc (1+ inc)) result))
(vla-settext
table
r
(setq c (1+ c))
(itoa (cdr (nth inc result)))
(setq c 0)
(princ)
