Intresections along line/Pline
John_nilsson6G97B
Message 1 of 24
John_nilsson6G97B
Hello experts!
I found this lisp by Tharwat, that counts intersections between two points and it creates a table from the layer info.
I need help to change it so instead of choosing two points I can select the line/pline and get all the intersections in one table for the whole length of the line. Also, if possible, ad at what length along the line/pline the intersection occurs. Would this be possible?
Here’s the code:
(defun c:Test (/ entities i number integer layers lst object point1 p
              height point2 result selectionset selectionsetname
              singlelayer model table r c inc
 (vl-load-com)
 (if (and (setq point1 (getpoint "\n Specify first point :"))
          (setq point2 (getpoint point1 "\n Specify Second point :"))
          (setq selectionset
                 (ssget "_F"
                        (list point1 point2)
                        '((0 . "LINE,*POLYLINE"))
          (setq p (getpoint "\n Table insertion point :"))
   (progn
     (setq height (if (zerop (cdr (assoc 40
                                         (setq st
                                                (entget
                                                  (tblobjname "STYLE" (getvar 'textstyle))
                    (cdr (assoc 42 st))
                    (cdr (assoc 40 st))
     (repeat (setq integer (sslength selectionset))
       (setq entities (cons (setq selectionsetname
                                   (ssname
                                     selectionset
                                     (setq integer (1- integer))
                            entities
       (if (not (member (setq singlelayer
                               (cdr (assoc 8 (entget selectionsetname)))
                        layers
         (setq layers (cons singlelayer layers))
     (setq i 0)
     (foreach layer layers
       (repeat (setq number (length entities))
         (if
           (eq
             (cdr
               (assoc 8
                      (entget (nth (setq number (1- number)) entities))
             layer
            (setq lst (cons layer (setq i (1+ i))))
       (setq result (cons lst result))
       (setq i 0)
     (setq model (vla-get-modelspace
                   (vla-get-activedocument (vlax-get-acad-object))
     (setq table (vla-addtable
                   model
                   (vlax-3d-point p)
                   (1+ (length result))
                   2
                   (* height 2.)
                   (* height 10.)
     (vla-settext table 0 0 "Section A - B")
     (setq r   0
           c   0
           inc -1
     (repeat (length result)
       (vla-settext
         table
         (setq r (1+ r))
         c
         (car (nth (setq inc (1+ inc)) result))
       (vla-settext
         table
         r
         (setq c (1+ c))
         (itoa (cdr (nth inc result)))
       (setq c 0)
 (princ)
Replies (23)
Message 21 of 24
ronjonp
@John_nilsson6G97B If you change this line: (setq pts (tracepline e 10)) to this (setq pts (tracepline e 20)) it works on your sample drawing.
This reduces the point list length from 444 to 389.
Message 22 of 24
John_nilsson6G97B
@ronjonp
Nice, you got it working again.
So I've been playing around with this now for a bit in other drawings. And I noticed that it doesent account for some lines. So from the first code i uploaded we are missing somthing.
I made an example out of bouth of them.
Message 23 of 24
ronjonp
Those 'crossings' are not at the same plane as your centerline:
Message 24 of 24
John_nilsson6G97B
@ronjonp
In my exampel drawing in post 22 they are.
This is really wierd. 🤔 How can they be so different when they have coordinates in this case SWEREF.
@Kent1Cooperany ideas why some lines dosent register?
