Insert lines inside the shape
luizhcastanho
luizhcastanho
How to insert lines inside the shape just by clicking inside?
The lines will be spaced every 43 cm and the rotation can be taken from any shape line as a reference.
paullimapa
How's about just using the Hatch > Settings dialog, selecting Type as User defined, choose whatever angle you want, enter 43cm for spacing then select the shape?
Paul Li
IT Specialist
@The Office
luizhcastanho
By hatching, it works if I can insert hatching by command and then explode it.
paullimapa
Sure. After running Hatch command then explode last
Paul Li
IT Specialist
@The Office
