vla-put-explodable not working
EnM4st3r
EnM4st3r
Hi, I want to change the explodable property of a Block but somehow that property is missing?
The Reference guide (2024) says it should have it:
But when I use vlax-dump-object on the block it doesnt show the explodable property..
also when using (vla-put-explodable (vlax-ename->vla-object (car (entsel))) :vlax-true)
i get this message "ActiveX server returned the following error: unknown name: Explodable."
Can anyone help me with that?
EnM4st3r
alright i know what was the problem. the object returned by vlax-ename->vla-object is not the object i need. It reutrns the Properties of the Block-reference but not the block-definiton. So what i need to do is filter trough the block definitions and then use the Blockdefinition for that.
