@loftpc wrote:
This really works well and is very much appreciated. This will save a tremendous amount of time. I look forward to seeing if you're able to include the apparent intersection snap.
I agree with @Kent1Cooper about the term "apparent intersection" and it may produce unexpected results.
We can include an extend option on the code but it may produce something like this
with acExtendBoth option
with acExtendThisEntity option
For apparent intersection, It's totally different with multiple objects selected than selecting only 2 objects.
Anyway, here's a code that includes the apparent intersection from _+dsettings but ignores most of it in the process
(vlax-invoke (car lst) 'IntersectWith e acExtendNone));<- acExtendOtherEntity a better option me thinks
in most cases endpoint mode is more than enough.
(defun c:mark2 ( / l2p osm cur fltr f f2 ss curves _inters lst l )
;;; pBe | Apr 2022 ;;;
(defun l2p (l)
(if l
(cons (list (car l) (cadr l) (caddr l)) (l2p (cdddr l)))
(setq osm (getvar 'osmode))
(setq func (lambda (cd) (if (= cd (logand osm cd)) cd )))
(setq func2 (lambda (x) (equal (distance pt x) 0.0 1e-8)))
(setq func3 '(entmakex (list (cons 0 "INSERT") (cons 2 "cor") (cons 10 pt))))
(setq cur (vl-some 'func
'(1 2 4 32 2048);< end/mid/cen/int/app int
(setq fltr "CIRCLE,ARC" )
(cond
((and
(setq f '(list (vlax-curve-getStartPoint e)
(vlax-curve-getEndPoint e)))
(= cur 1 ) (setq f2 f))
((= cur 2)
(setq f2 '(list (vlax-curve-getPointAtParam e
(* 0.50 (apply '+ (mapcar '(lambda (p)
(vlax-curve-getParamAtPoint e p)) (eval f)))))))
((setq curves (= cur 4))(setq f2
'(list (vlax-get (vlax-ename->vla-object e) 'Center))))
((setq _inters (member cur '(32 2048)))
(cond
((null (setq ss (ssget (list (cons 0 (if curves fltr "*LINE,ARC")))))) )
( _inters
(repeat (sslength ss)
(setq lst (cons (vlax-ename->vla-object (setq en (ssname ss 0))) lst))
(ssdel en ss)
(while lst
(foreach e (cdr lst)
(foreach pt (l2p (vlax-invoke (car lst) 'IntersectWith e acExtendOtherEntity));<-- this here
(if (not (vl-some 'func2 l))
(setq l (cons pt l))
(setq lst (cdr lst)))
(if l (foreach pt l (eval func3)))
((repeat (setq i (sslength ss))
(setq e (ssname ss (setq i (1- i))))
(foreach pt (eval f2)
(progn
(eval func3)
(princ)
HTH
