AutoCAD 2023: A lisp file that can identify the dwt template based on which the dwg file is originally created,
JamaL9722060
JamaL9722060
I would appreciate if experts can share a lisp file that can identify the dwt template based on which the dwg file is originally created
Jamal Numan
cadffm
Hi Jamal,
we are talking about this not the first time, or?  <CLICK-for-Jamals-Q months ago>
Why you asking again, because of another Product (2023 instead 2022)?
If so: You don't need to ask for 2024,2025,2026,2027 and so on. It will be every time the same.
Answer:
1. For files from outer : It is impossible.
   You can take every file and change all things, because of this - it is impossible to say what the real source dwt was.
2. Some Files are neither nor acad.dwt or acadiso.dwt, and some file are create without any dwt file..
3. This is not your real task/job/issue - you ask the wrong question.
    So let me try to help you to ask the right question:
   Why do you like to know that?
Sebastian
JamaL9722060
You are right. I’m gonna reformulate the issue differently
Jamal Numan
cadffm
I'm interested how the new question will look like.
You can use Lisp to check all the facts,
but the program cannot decide whether it is right or wrong.
Sebastian
