Select all dimensions not 1/128 precision?
DC-MWA
DC-MWA
I'm looking for an easy way to select all dimensions in a drawing that are not 1/128 precision.
I'm hoping someone has done this and can point me in the right direction.
Ultimately I would like to change the color of all non 1/128th dimensions to yellow.
Thank you in advance for any assistance received.
hak_vz
@DC-MWA
Maybe something like this?
(defun c:foo ( / ss i eo)
	(setq ss (ssget "X" '((0 . "DIMENSION"))) i -1)
	(cond
		((and ss)
			(while (< (setq i (1+ i))(sslength ss))
				(setq eo (vlax-ename->vla-object (ssname ss i)))
				(if(vlax-property-available-p eo 'PrimaryUnitsPrecision)
					(if (/= (vlax-get eo 'PrimaryUnitsPrecision) 7)
						(vlax-put eo 'Color 2)
	(princ)
Miljenko Hatlak
DC-MWA
This is perfect! Thank you very much!!!!
hak_vz
@DC-MWA I'm glad it works for you. I work with SI units, so setting proper combination of architectural units in Acad was bigger problem for me than finishing the code.
Miljenko Hatlak
