Insert Attribute in Polylines or Lines
andre_andreoni
Message 1 of 9
andre_andreoni
I have a project with copper pipelines of different diameters, however I would not like to create several layers with different diameters to filter layers with the same characteristics. What I believe to be more practical, is to create an attribute in polylines or lines, where I can insert the respective diameter of each tube into the properties, and therefore make a filter per attribute (I do it with lisp), and count the linear meters of each diameter (I can use another lisp that I have). Is there any lisp or command to insert attributes into polylines or lines to put a numeric value?
Replies (8)
Message 2 of 9
Kent1Cooper
If they're Polylines, just give them global widths corresponding to the pipe diameters.  An AutoLisp routine could easily find all Polylines of each width, and report their total lengths.
Kent Cooper, AIA
Message 3 of 9
andre_andreoni
I know this sollution, but the problem is, when you need to print the drawing the thickness will be impresseed. But thank you so much.
Message 4 of 9
dbroad
You can add xdata.
Architect, Registered NC, VA, SC, & GA.
Message 5 of 9
ec-cad
How about inserting a little 'block' with maybe a small triangle made of lines, and add attributes to that block,
making them 'invisible'. If the Diameter / Length are the same, you can 'copy' those blocks, once you fill
in the details. You will be able to 'see' those added blocks, so you know which pipes are identified.
Then later, you can get a selection set of that 'blockname', grab the attribute values, and
report as needed.
ECCAD
Message 6 of 9
CADaSchtroumpf
You can try this.
This uses Xdata as well as ldata.
in the code you can personalize/complete the dn table (at the start of the code) while respecting the formatting (see the commented description at the start of the code)
After using the code you can query the polyline with (commented at the end of the code) to obtain the information:
(mapcar
	'(lambda (x ent / ent)
		(vlax-ldata-get (vlax-ename->vla-object ent) x)
	'("1" "2" "3" "4" "5" "6")
	(list (setq ent (car (entsel))) ent ent ent ent ent)
A selection of the objects concerned by the application is possible with:
(sssetfirst nil (ssget '((0 . "LWPOLYLINE") (-3 ("PIPELINE")))))
Message 7 of 9
АлексЮстасу
Hi, @andre_andreoni
You can use free XDTOOLS to work with attributes (descriptive data, characteristics) of objects in XData:
- XDTOOLS_MDEFINE - create and edit XData definitions.
- XDTOOLS_ADD - add the required XData to all specified objects.
- XDTOOLS_VEDIT - view and edit XData contents.
- XDTOOLS_SELVALUES - selecting by desired XData field values.
Etc. - 20 commands.
If you need to make inscriptions from XData field values - XDLABEL.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 8 of 9
baksconstructor
Most likely this is what is needed - MyPropertiesCAD
Message 9 of 9
Sea-Haven
This worked for me I drew plines with a width of 0.025 ie 25mm pipe it drew a single skinny line, looked like a single line in the pdf. The advantage is get length and width * 1000 etc. Maybe its my Bricscad. Did not test very much.
Fat line is 5 others are 0.025 & 0.016
